20 Most Recent
RCA 7in twin screen portable Questions & Answers
My son locked the tablet and dont know the password
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
Rock ola 55015-1A Amplifier add bluetooth
Adding Bluetooth functionality to a Rock-Ola 55015-1A Amplifier involves a few steps and considerations to ensure compatibility and proper functionality. Here's a general guide on how to add Bluetooth to your Rock-Ola 55015-1A Amplifier:
1. Gather the Necessary Equipment:
- Bluetooth audio receiver module
- Wiring tools (soldering iron, wire strippers, solder)
- Audio cables (3.5mm or RCA)
- Power supply (if required for the Bluetooth module)
"My marantz avp 8802a sub out 1 not working properly ones remove rca cable and fit back then sub work ?
can you elaborate all that, no sub maker/brand model told)
tell it all what works and does not work both.
ones =once?
well it has 2 jacks sub1 and sub2.
so swap them if the problem fails on moved sub the sub is bad.
if the new moved sub fails on same channel the channel is bad in the head, or cables are bad.
then swap cables.
there are 3 fail points here.
the main head. out. sub1/2
2 cables RCA SIMPLE COAX , easy to buy cheap and replace.
2 subs.
super easy to diagnose any like this 2 subs. (it's redundaNT bliss)
my actual sub has power AC and rear volume and on/off on rear of sub speaker, so any of that can be wrong, but not told you what you have, we can not see what you have at hand.
Why does my car audio amplifier power on but has no sound?
This is a sign that the amp is being overtaxed by a subwoofer or other speakers to the point where it simply can't provide enough power. In home audio setups, clipping is typically caused by an underpowered amp or inefficient speakers, but loose or burnt wires can introduce similar problems in cars.
