20 Most Recent
Genie Company Genie Series III 3 Button Remote Control Questions & Answers
How can I connect 3-button remote to my genie intellicode model IS550/A?
The button closest to the Genie logo is the one that works, I just programmed it by pressing & holding the black button underneath the light cover until the red light above the button goes solid then blinks then stops blinking. Next I pressed the same button once and the red light blinks then pressed the button on the remote once then once more and it was all set.
Genie home alarm system keeps beeping
Find your user manuel. If you do not have it type in the system you have into Google and put "user manuel" after it. (i.e. Genie user manuel) Look in the table of contents under the troubleshooting section and follow the steps listed. The exact panel type should be searched for Genie...then there should be some model number.
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
