20 Most Recent Apple iPad 2 WiFi Black (MC769LLA) Tablet PC Questions & Answers
Try doing a hard reset by holding down the home button and the sleep/wake button until you see the apple logo. If the screen continues to flash it is most likely a hardware problem and you should contact Apple to replace the device.
Apple Customer Support
http://www.apple.com/support/contact/
Apple iPad 2... | Answered on Sep 25, 2011
Im not sure what you mean by 'link'. Maybe you mean Sync?
If you are looking to Sync the two devices, you have to upload your data to icloud. Apple gives us all 5GB of free storage. I normally sync my Notes App, Contacts, Calendar, Reminders and a few other. You have to be using the same Apple ID on both devices.
Go to your Settings. Go to iCloud. turn on the apps you want to sync.
Apple iPad... | Answered on Jun 30, 2020
You need to do a system restore. Try this (https://support.apple.com/en-gb/ht201263) or this (https://support.apple.com/en-us/HT204770)
Apple iPad... | Answered on Mar 06, 2020
best is a microfiber towel which you can buy in many shops and can also be cut in small pieces.
  • microfibers lift dust and oils from delicate surfaces without the use of chemicals
  • Ideal for eyeglass lenses, camera lenses, displays, binoculars, microscopes and other delicate surfaces
  • Non-scratching, non-linting
  • Dirt and particles are trapped within knitted tufts of the fibers
  • Ribbon-shaped fibers lift dirt and grease instead of rolling over it
clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-0.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-2.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-5.jpg
Apple iPad... | Answered on Feb 24, 2020
In your case, you can still try some methods to fix it. Just follow below steps.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
For more methods, check: How to Unlock iPad?
Apple iPad... | Answered on Feb 15, 2020
There are a number of ways to unlock iPad. You can resort to iTunes or iCloud "Find my iPhone" feature. Just follow below steps to do that.
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Of course, there are different ways to update iPad. You can follow below steps to do that.
If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
  1. Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
  2. Connect your iPhone to a WiFi network.
  3. Tap "Settings > General > Software Update" successively.
  4. Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
  5. Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
For more methods, check: How to Update iPad
Well, this isn't definite, but it could be worth a try, but you'll lose your information on your iPad air, so if you have data on it you also don't want to lose, I don't believe it can be done, without some hacking techniques. Backup your iPad 1 to iTunes, then erase all data on your Air. Once you have now plug your air into the computer you just backed up your iPad1 and select to restore from backup. Like I said you will olds all of the data on your air, and if it's not duplicated on your iPad 1, then it'll be gone forever and probably not worth it for this one game.
You gave an android device name, and then an iPad error message, so I'm not sure sure what kind of device you have, but I will tell you how to restore an iPad and an Android to factory, which is I believe what is you want to do. Both options can be done without unlocking the device.
First, Android.
Now, iPad.
Use iTunes to restore your iPhone iPad or iPod to factory settings
Apple iPad... | Answered on Jan 10, 2020
I'm sorry but do you have an iPad or an Android Tablet? Android won't run on an iPad as it uses iOS operating system not android.
Apple iPad... | Answered on Dec 26, 2019
Apple iPad doesn't support SWF files, you have to use special SWF to iPad Converter to play swf videos with ipad, plus, you need a special swf player, like this one
http://swfplayer.info/
Apple iPad... | Answered on Oct 30, 2019
Go to setting
go to General clock on that then go to software click on that and see if there software update available
Try to restart the iPad :
turn it off, wait 10 for seconds, then turn it back on.
Apple iPad... | Answered on Oct 06, 2019
Hello, sorry to hear about your problems. You haven't really described the problem with any details so I will give you the best support I can with what information your provided. There could numerous problems.
1) Slotomania is down for maintenance of is experiencing technical difficulties. This is common for apps and if it is the case all you can do is wait for their support staff to fix the issue.
2) You have said "Can't Connect" so I assume you can't connect to the app server once you start the app. If a login is required double check your login details. Again, they may be having trouble on their end.
3) Give your tablet a reboot. Just simply power it off and back on. This may resolve the issue.
4) Uninstall and reinstall the app. It is possible some app system files are corrupted , even if it worked before. You would be surprised how many times just reinstalling something actually will fix the issue at hand.
Please let me know if you questions. Clarification on your problem would help in resolving it faster.
Apple iPad... | Answered on Sep 15, 2019
In fact, there are different ways to reset iPad password. You can follow below method to have a try.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Apple iPad... | Answered on Jul 23, 2019
It's usual for us to forget the passcode, however, there are several ways to reset the iPad password. Just follow one of them shown below.
iPad Air
iPad mini/iPad pro
Try below steps to unlock your iPad Air.
Apple iPad... | Answered on Jul 18, 2019
If you need to export videos from iPad to computer, there are multiple methods to complete this task. Just follow one of them.
You PC Windows Explorer is also a good free method to dispose how to transfer videos from iPad to PC without iTunes. This only needs a proper USC cable and several clicks. Follow me to check out the detailed steps.
1. Using a suitable USB cable to connect iPad to PC and then click on "Trust" button on your iPad to trust your computer.
2. Launch Windows Explorer on your PC and your iPad icon will display in the interface. Tap on the iPad icon and then choose "Internal Storage > DCIM" to click on. Thus, your iPad videos and photos will show in the folder. At last, you can copy and paste the iPad videos to a PC folder to save them.
This way to cope with how to transfer videos from iPad to PC without iTunes is quite easy. You can have a try with this simple solution to realize your goal.
transfer-videos-from-ipad-to-pc-without-itunes-but-windows-explorer-6-2ka233npl0212ndjbhnpio3z-3-0.jpg
For more methods, check: How to Transfer video from iPad to PC with or without iTunes
Apple iPad 2 WiFi Black (MC769LLA) Tablet PC Logo
Popular Tags
3 questions posted
Top Apple Tablets & eReaders Experts
John mullen
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
ipad scren flahes occaisionally
  • Tablets & eReaders
