20 Most Recent
Plantronics K100 Bluetooth Headset Questions & Answers
K100 not charging or responding
Here is something you can try. If you're still having problems and it's less than a year old, return it to your retailer for warranty replacement or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
K100 Speakerphone: How to Perform a System Reset
1) Push and Hold the On/Off button and, without letting go, insert the charger.
2) Let go of the button as soon as you see a steady light on the speakerphone.
3) Unplug the charger.
4) Wait 2 seconds and turn the speakerphone on again.Good luck from
Headsets Direct!
Plantronics k100 I have no volume.the only thing I
One possibility: The K100 needs to be re-paired to your phone.
When powering on the K100 it searches for the cell
phone so you want to make sure your phone is in pairing mode and no
other bluetooth device is interfering with the procedure so the phone
within range can
be connected by tapping the Multi-Function button.Follow the link to the
Plantronics K100 User's Guide for more help and instructions.Good luck from
Headsets Direct!
When I first bought the
One possibility: If your new phone is
paired but not connected because the K100 is looking for the old phone.
When powering on the K100 it searches for the last connected cell
phone. If the last connected phone is not within range, or the
Bluetooth feature is turned off on the phone (which hopefully the first iPhone is turned off or at least out of range), then another phone
within range that has been previously paired with the speakerphone can
be connected by tapping the Multi-function button.
For additional help,
Plantronics K100 Users GuideGood Luck from Headsets Direct!
On my plantronics cs540a i do not get a beep to let me know there is an incoming call.
If your Plantronics CS540A is not providing a beep to let you know there is an incoming call, there are a few things you can try to troubleshoot the issue:
- Check the settings: Make sure that the ringer volume is turned on and set to an appropriate level. You can adjust the ringer volume using the button on the base of the Plantronics CS540A or through the settings on your phone or computer.
- Check the mute button: Make sure that the mute button on the Plantronics CS540A or on your phone or computer is not engaged.
- Check the connection: Make sure that the Plantronics CS540A is properly connected to the phone or computer.
- Check the battery level: Make sure that the battery on the Plantronics CS540A is charged and that there is enough battery power to provide a beep.
- Check the software updates: Make sure that the Plantronics CS540A has the latest software updates installed.
- Check the settings of your phone or computer, there could be an option to turn off the ringtones of the headset.
- Check the volume of the ringer, it should be set to an appropriate level.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the ringer can vary depending on the model and manufacturer.
My plantronics cs350 wireless and headset no longer beeps when phone rings
- Make sure the volume on the headset is turned up.
- Check the settings on your phone to ensure that the ringtone volume is turned up and that the ringtone is not set to vibrate only.
- Make sure the headset is properly paired and connected to your phone.
- Check the battery level on the headset. If the battery is low, charge the headset.
- If none of the above steps resolve the issue, you can try resetting the headset to its factory settings.
If none of these steps resolve the issue, you should contact Plantronics customer support for further assistance.
Audio notification issue with BT600
since re-pairing caused this, please perform another re-pair and check for the pre-sounds beeps again. I'm guessing that you might have accidentally skipped a step in your first attempt and it led to this sound occurring.
Thank you.
PLANTRONICS SG_106 BATTERY REPLACEMENT
If it is the internal CMOS battery, it should be an easy swap. There is a high potential that this will reset the radio settings and you will lose all saved channels/frequencies, and have to reprogram them. Cell size is usually a CR2032 or CR2032R. The R is for the rechargable version, but not all equipment will do that. If it isn't a black socket that you can easily pop batteries in and out of, you may have to buy one with solder tabs or wires already attached. I don't reccomend trying to solder directly on the battery because it can fail and even expload from the heat.
