SOURCE: I can not hear anything on my pearl when I answer the phone
when in the call push the volume button on the side of the blackberry
SOURCE: plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
SOURCE: I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
