20 Most Recent
Bush DW5F 22 in. Dishwasher Questions & Answers
Dishwasher over filling
try connecting the the hot water rather than the cold. I had this problem before when i only had a cold water feed. to get round it i poured some boiling water in first , left it for about 30 seconds then started the wash cycle
Door seal
get on the mfg. website for listed dealers if no luck call the mgf. for info.
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
