20 Most Recent
Samsung HLR5087W 50" Rear Projection HDTV Questions & Answers
High pitch sound on power up and takes a long time to come on
probable color wheel for the sound which is described sometimes as fan like or high pitched---common issue and you tube has video instructions by brand/model for replacing it.Takes a long time to come on may be the lamp if it has not been replaced in a long time(life is 2 years) and both are the most common parts to fail in this set.
lamp is from another brand but typical for your set.
Samsung dlp tv picture turns off sound stays on
HelloCheck whether the lamp life hours are going to be out. Refer to its user manual for details. DLP chips fault is very rare; unless you have handled them very carefully. Check the lamp and BALLAST baord that supplies voltage to lamp.Picture of the ballast baord to your TV is attached.
I have replaced the lamp,
Blinking of the 3 led light at the front panel is an indication that the lamp failed to turn on after 3 consecutive attempt of the set. If you've already replaced the ballast board and the lamp and yet the symptoms remain the same, you must check the supply voltage from the power supply board (CN801) feeding the ballast board. If not present, click this
LINK for the replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Ok my samsung hlr5087 has
I'm afraid it is dmd module that is bad and need to be replaced, it would cost approx $800 plus labor so buying a new lcd tv would be good decision.
Thanks.
My samsung hl-r5087w has black
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
Liquide coms from RGB back projection tv.
The CRT will need to have new Coolant and new seals installed, and any circuit boards that were dripped on will need a very detailed cleaning to remove any residule as it can ruin the circuit board traces and solder connections
Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
I have hlr5087 lost the
Do you mean you hear sound? But no picture? Is the sound normal or do you hear some kind of high-pitched noise along with it?
Please provide this info so that we can continue with the diagnosis.
Broken Glass Base
part # bp96-00623a bottom glass stand. go to this link to order 310.00 dls have a nice day
http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=HLR5087W&modelid=351619
