20 Most Recent Toshiba Sony CDXT69 CD Changer Questions & Answers
I need the wiring diagram for a toshiba tx-904
red ignition w-fl speaker(+) w/b-fl speaker (-) gray-fr speaker (+) gray/black -fr- speaker(-) yellow-constant 12v(+) blue motor antnna rca gray-rear left - rca black rear right black ground
8/25/2014 3:24:23 PM • Toshiba Car... • Answered on Aug 25, 2014
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks. Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference. Switch the input on your TV to "Component".
12/29/2013 8:52:26 PM • Toshiba Car... • Answered on Dec 29, 2013
0answers
2002 yukon gmc my speaker is out and I need to
Standard Yukon front and door speakers are 5-1/4". Most aftermarket speakers will require an adapter bracket.
Also, there are custom made kick panel enclosures for the Yukon.
Installing new speakers in the doors is a rather easy process. You just need to remove the door handles, door lock and window switches, and the door panel, remove the speaker, disconnect it, plug in the new speaker, and then reinstall everything you took off in reverse order.
One online aftermarket retailer, www.crutchfield.com will send you an "install guide" tailored to your vehicle when you purchase from them. They will also include any brackets, adapters, or wiring harnesses needed, usually at no additional cost.
In order to be more specific, additional information on your vehicle would be required. Is it the Yukon, Yukon Denali, Yukon XL, or Yukon XL Denali and does it have the Bose system with or without OnStar, and does it have the OEM subwoofer?
With this information, Crutchfield or many other online retailers can help you select exactly what you want.
3/26/2009 7:36:18 PM • Toshiba Car... • Answered on Mar 26, 2009
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
6answers
Car Audio & Video Logo
4 questions posted
Top Toshiba Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Toshiba Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Car Audio & Video
Most Popular Question
need pin outs sony cdx s2010
  • Car Audio & Video
