Tip & How-To about Car Audio & Video
Need a Vehicle Radio Code?
There are only three ways to do this.
1. Take it to your local local dealership for your make of vehicle. You will need to provide the registration document and they will give you the code for free based on the vehicle VIN Number.
2. Look for a small white sticker in the glove compartment or the centre console. When the car is new, this sticker is supplied with the manual with those instructions.
3. You pay an online Radio Code Decoding company. Many of them say 'Free', but most charge about $15 or £12 UKP. The major sites are trustworthy and will work with you, or refund if the code doesn't work. The sites need the Serial Number of the radio which is either engraved to the radio chassis, or on a sticker at the rear or sides hidden from view.
This link is for Fiat, change the Search Query to your make.
https://www.google.com/search?q=Fiat+radio+code
Car Audio & Video Logo
3answers
I need the code for a becker BE 1492 serial# P1033487
Posted by ADMIN... on May 19, 2022
2answers
radio code for Suzuki Ignis 2006.
2014 Chevy Impala radio saying 'loc' any tricks to getting it unlocked.
It sounds like it needs a code. Did you disconnect the battery? I have answered this question so many times, I wrote it as a Tip.
I also found this
The radio will display "LOC" indicating the Theftlock system is activated. Step 2: Press and hold preset buttons 1 and 4 for ten seconds. (If you don't have a fourth preset button, press and hold presets 2 and 3.) The radio will display a three digit number.
How to Unlock Your Chevy or GMC Radio Without Paying a ...
Water in front differential
it is a 2007 vehicle so there would be no warranty on the diff
as for the cost , replacement diffs from wreckers. junk yards with the same ratio would be less that 1/2 that so I think that you are being touched in the wallet area or get a fully rebuilt diff from an accredited diff and transmission specialist shop
The dealership is trying to get out pf paying for the problem. I'm not going to say this is a common problem but it does seem to happen a lot. The axle seals leak quite frequently also the pinion seal leaks.There might be also be a problem with the vent, the hose could have came loose or hole in it. There is also an oring seal around the filler hole that may not have been installed properly.
If the dealership fails to help you call the GM customer assistance center and lodge a complaint. Chevrolet Customer Assistance Center 1-800-222-1020
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
