20 Most Recent
Kenmore 744-10BH Mechanical Sewing Machine Questions & Answers
Oiling sewing machine
Sorry couldn't find a free manual - check here though, they are only $10;
http://www.sewusa.com/Sewing_Machine_Manuals/kenmore_Sewing_Machines_385.htm
although they dont have the exact manual for your model, the oiling instructions should be the same for all the 385 models.
it is a good site - you can contact them direct for more info and you might get lucky;
http://www.sewusa.com/index.htm
These guys are also worth a try;
http://www.sew4less.com/manuals.php
They claim to offer a manual for your exact model, but the picture shows a generic manual which they say will offer the same info
Hope this helps, good luck, please post again if you need more help :)
Missing manual
RE: Kenmore Jaguar Quick System sewing machine, model # 158.1070180
I have this machine and the manual. I even still have the receipt from
when I bought it in April 1990. It just stopped working this year. I
might hold on to it and get it repaired one day. Handy little machine, I
took it everywhere with me. Is there someplace I could send you a
scanned copy if you're still looking for it?
Tina
How do you adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine?
To adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine, you can follow these steps:
- Turn off the sewing machine and unplug it from the power source for safety.
- Remove the needle and presser foot from the machine.
- Locate the feed dog adjustment screw, which is usually located on the backside of the sewing machine, near the feed dogs.
- Use a screwdriver to loosen the feed dog adjustment screw. It might be a slotted screw or a thumbscrew, depending on the model.
- Gradually adjust the height of the feed dogs by turning the adjustment screw clockwise or counterclockwise. Clockwise rotation raises the feed dogs, while counterclockwise rotation lowers them. Make small adjustments and test with a scrap fabric after each turn to achieve the desired height.
- Once you have set the feed dog height, tighten the adjustment screw securely.
- Reinstall the needle and presser foot, and plug in the sewing machine.
- Test the machine with a piece of fabric to ensure the feed dogs are working properly and at the desired height.
It is important to consult the sewing machine manual for specific instructions related to your model, as the location of the adjustment screw may vary.
How do I find the manual for a model c970 555624
You can try to find the manual for your Kenmore model c970 555624 by following these steps:
- Visit the Kenmore website at www.kenmore.com.
- Click on "Customer Care" at the bottom of the page.
- Click on "Manuals & Guides" in the "Quick Links" section.
- Enter "c970 555624" in the search bar and click "Search."
- If the manual is available, it should appear in the search results. Click on the manual to view or download it.
If the manual is not available on the Kenmore website, you may need to contact Kenmore customer service directly to request a copy.
The lever for the presser foot on my Kenmore 158.441 sewing machine is locked in the down position
If the lever for the presser foot on your Kenmore 158.441 sewing machine is locked in the down position, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
- Check the presser foot: Make sure the presser foot is properly installed and aligned on the machine. If the presser foot is not properly installed or aligned, it can cause the lever to become stuck in the down position.
- Check the presser foot lever: Inspect the presser foot lever for any visible damage or looseness. Make sure the lever is not bent or broken and that it is properly aligned and connected to the machine.
- Check the threading: Make sure the machine is properly threaded. If the thread is not correctly aligned or tensioned, it can cause the presser foot lever to become stuck in the down position.
- Check for any other visible issues: Inspect the machine and its components for any visible issues that may be causing the presser foot lever to become stuck in the down position. This can include debris or foreign objects that may have gotten stuck in the machine, or damage to the machine or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the machine serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
