20 Most Recent Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Questions & Answers
3answers
Machine wont pick up bobbin thread
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
11/26/2017 7:53:21 AM • Kenmore Drop-In... • Answered on Nov 26, 2017
2answers
Sewing machine motor seized up and broken parts near bobbin
Without actually seeing the problem myself I would only be guessing. I would recommend taking it to a Sew & Vac shot and get their opinion and a repair quote.
11/22/2017 4:07:43 PM • Kenmore Drop-In... • Answered on Nov 22, 2017
My needle thread keeps breaking.
Sounds like it needs a cleaning underneath the bobbin case, lint or thread can be trapped underneath. Use a new paint brush to do this then oil it according to your manual.
9/21/2017 1:02:28 PM • Kenmore Drop-In... • Answered on Sep 21, 2017
2answers
Needle thread is wrapping around the bobbin case
Not to familiar with the industrial machines. However, even with domestic models. the position of the 'needle' bar at the time you remove your fabric, does make a difference as to weather it pulls our smoothly or, you are going to get that "extra" loop. Needle should be half way up or all the way. maybe this might helpSewing Machine Tech
11/17/2016 5:18:28 PM • Kenmore Drop-In... • Answered on Nov 17, 2016
2answers
needle won't pick up thread I think the timing is off, how do I retime it?
5/30/2015 3:26:32 PM • Kenmore Drop-In... • Answered on May 30, 2015
What causes the bobbin case to pop up as I am sewing?
It may not be in all the way. Mine has a small lever in the middle that I must hold out when installing.
11/22/2014 5:15:57 PM • Kenmore Drop-In... • Answered on Nov 22, 2014
How to raise and lower feeder feet
I'm not 100% sure, but stitch #9 is neither straight nor zigzag/stretch, so I'm thinking that's where you turn off the feed dog and the needle positioning.
10/5/2014 3:28:20 AM • Kenmore Drop-In... • Answered on Oct 05, 2014
I have a zig zag sewing machine Model#1231 (43 yrs old) and need a carrying case
I would suggest searching in thrift shops, and older song machine repair shops you might be able to locate a carrying case there. If not any modern caring case will work.
9/28/2014 7:34:25 PM • Kenmore Drop-In... • Answered on Sep 28, 2014
0answers
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
2/26/2014 5:52:15 AM • Kenmore Drop-In... • Answered on Feb 26, 2014
The screw by the bobbin winder has come out. I can't get it to thread back in - it doesn't tighten. How can I fix this?
Hi Valerie, looks like your touch pad does not working. please go for the repair maybe its a little loose contact with flex cable and connecting port in the inside. regards, nuwan.
1/16/2014 8:05:29 AM • Kenmore Drop-In... • Answered on Jan 16, 2014
Foot petal does not advance machine
Replace the pedal
1/10/2014 6:09:38 PM • Kenmore Drop-In... • Answered on Jan 10, 2014
2answers
Looking for an Owners Manual
hi go to managemyhome.com check for manuals they have this there. and also all other brands free!
good luck...........
12/30/2013 3:16:47 AM • Kenmore Drop-In... • Answered on Dec 30, 2013
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
161 questions posted
Top Kenmore Sewing Machines Experts
David Shaub
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Sewing Machines
Most Popular Question
my husqvarna sewing machine has started
  • Sewing Machines
