20 Most Recent Whirlpool Clothes Washer Tub Stablizer Snubber Pad 358336 Questions & Answers
Whirlpool Duet Sport loud vibration during spin cycle
does it do a dance on spin ?....... is it a new machine .if so did you remove all the transit parts if not remove them ?
4/27/2014 9:42:24 PM • Whirlpool... • Answered on Apr 27, 2014
0answers
Whirlpool Stylemaster 4214164, top loading washer. What year is Stylemaster Whirloool 4214164 please?
Question edited for clarity. You can decode from the serial number. This says 1982.
Whirlpool Date Codes
Electrical-Forensics https://www.electrical-forensics.com > MajorAppliances An alpha code in the model number indicates the year the model was introduced. Before 1981, the second digit of the model number contained the code. After 1981, ... This one is 1993 https://www.fixya.com/support/t1006047-whirlpool_stylemaster_4214164 ..
4/17/2024 11:04:13 PM • Whirlpool... • Answered on Apr 17, 2024
How do i get a necklace stuck in holes of my Whirlpool thin twin washing machine?
It won't be easy - the necklace went through the hole so logically it should come back, unfortunately it is the nature of a necklace to be a random structure unless some tension is applied; the links or whatever are apt to go sideways and jam in the hole. In an extreme case the necklace could be knotted... If it is knotted there is no chance of removal and the solution is either to dismantle the washer or to break the necklace. Positioning the drum so the necklace is under tension under its own weight and with some jiggling and the application of lots of patience and some luck it should come back through the hole.
4/7/2024 3:13:20 AM • Whirlpool... • Answered on Apr 07, 2024
Whirlpool washer 8525492 -a load capacity
What is the model number for this washer?
4/5/2024 7:35:23 PM • Whirlpool... • Answered on Apr 05, 2024
Whirlpool heavy duty commercial washer # cae2743800 will not start after coins inserted and start button held
Check the Coin Mechanism: Ensure that the coin mechanism is functioning correctly. Sometimes, coins may get stuck or not register properly. Verify that the coin slots are clear and that the mechanism is engaging properly. If there's an issue with the coin mechanism, it could prevent the washer from starting. You might need to clean or repair it. Inspect the Wiring: There should be a harness with two wires that go into the coin mechanism box. Check if these wires are intact and properly connected. If you find any damage or loose connections, consider repairing or replacing the wiring. Bypass the Coin Mechanism: If you suspect that the coin mechanism is causing the problem, you can bypass it temporarily. Cut the wires going into the coin mechanism and insert a push button switch in the line. This will allow you to manually start the washer without relying on the coin mechanism. If you're unsure how to do this, consider contacting a local repair shop for assistance. Check for Other Issues: Inspect other components such as the lid switch, control board, and start button. Any malfunction in these parts could prevent the washer from starting. Make sure the washer is plugged in and that there are no tripped circuit breakers or blown fuses.
4/3/2024 3:28:33 AM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool duet steam washer displaying F 20 error code during wash cycle. Water seems to be flowing just fine. I've unplugged it several times to clear the code but it's not working.
The F20 error code on a Whirlpool Duet Steam Washer typically indicates a water inlet problem. It means the washer is not getting enough water to continue the wash cycle. This can be due to several reasons, even if it seems like water is flowing fine at first glance. Here are steps you can take to troubleshoot and potentially resolve the issue:
  1. Check Water Supply Hoses:
    • Ensure both the hot and cold water faucets are fully open.
    • Inspect the water inlet hoses for kinks, bends, or twists that could restrict water flow. Straighten out any issues you find.
    • Turn off the water supply, disconnect the hoses from the back of the washer, and check that the filter screens inside the water inlet valve are not clogged with debris. Clean them carefully if needed.
  2. Water Pressure:
    • The washer requires a certain amount of water pressure to function correctly. Low household water pressure can lead to insufficient water flow to the washer. Make sure your home's water pressure is within the washer's required range.
  3. Check for Siphoning:
    • Make sure the drain hose is correctly installed. The end of the hose should not be too far down the standpipe, and there should be an air gap to prevent siphoning.
  4. Inlet Valves:
    • If the water hoses and screens are clear, there might be an issue with the water inlet valves themselves. They might not be opening fully due to electrical issues or mechanical failure.
    • The inlet valves can be tested with a multimeter for continuity to ensure they are functioning correctly. If they lack continuity, they need to be replaced.
  5. Flow Meter:
    • Some Whirlpool Duet models have a flow meter that measures the amount of water entering the washer. If this component malfunctions, it could mistakenly signal that there's not enough water, even when there is.
    • Diagnosing a flow meter requires some technical knowledge and a service manual for your specific model.
  6. Pressure Switch:
    • The washer uses a pressure switch to monitor the water level. If there's an issue with this switch or the hose connected to it, the washer might incorrectly interpret the problem as insufficient water flow.
    • Check the pressure switch and the hose for any blockage, disconnection, or damage.
  7. Reset the Washer:
    • Since unplugging the washer hasn't cleared the error, after checking the above, try to reset the control board by unplugging the washer for about 5 minutes, then plugging it back in.
If after trying these steps the F20 error persists, it may be time to consult the manual for more specific troubleshooting steps for your model or contact a professional appliance repair service. Sometimes, the problem could be related to the washer's electronic control board or other components that require professional diagnosis and repair.
3/10/2024 2:57:47 PM • Whirlpool... • Answered on Mar 10, 2024
Washing machine not turning well belt is new but there is more noise on the drum
Is the correct tension on the belt; too much and the bearing could be getting damaged. If you remove the belt, check the drum moves freely with no noise. If noisy, replace the bearing or purchase a new machine.
2/21/2024 7:50:38 AM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool Washer WFW94HEAW0 Front Load Washing Machine. Trapping Water in Unknown Area.
Stale smells come from not drying the front gasket trough just inside the door. Your bleach isn't cleaning that area. Use Tilex Mold spray on it. Clean and dry the door glass as well and leave the door open for a few hours after a wash or leave it open all the time. If it is dry, it can't smell.There will always be some water in the pump area, but if you remove the pump filter cover, that releases and water left behind.When you use bleach always do whites or your tea towels next. You can also dilute by adding a couple of jugs of water first.There is a trick to look for rattling items between the inner and outer drum. Put a good flashlight against the holes in the drum and you can see what is below without getting the glare from the drum.These websites give you a full parts schematic showing all the parts and their positions.https://www.appliancepartspros.com/tub-basket-parts-for-whirlpool-wfw94heaw0.htmlWhirlpool Washer WFW94HEAW0 - OEM Parts & Repair Helppartselect.cahttps://www.partselect.caCanada Wide Same-Day Shipping For All In-Stock Parts. Shop Canadian And Avoid Customs ' 2 Million Parts Ready To Ship. OEM Parts & Accessories. One-Year Warranty. Money Back Guarantee. Free Repair Help & Videos. Types: Dishwasher Parts, Dryer Parts.
2/17/2024 9:23:21 AM • Whirlpool... • Answered on Feb 17, 2024
Whirlpool dishwasher will only drain
If the machine runs a while and then drains, it is like that there is a leak and the leak sensor has been activated. There is a tray between the base of the machine and the kitchen floor.
2/13/2024 11:52:14 PM • Whirlpool... • Answered on Feb 13, 2024
I have a whirlpool AWOE1012 washing machine and I run all kinds of programs and there is always an f08 error. Can anyone help me and what is the nature of the fault please?
Check if the water is getting hot. F08 indicates that the heater is an open circuit so check the heater for continuity with a meter.
12/12/2023 10:10:52 PM • Whirlpool... • Answered on Dec 12, 2023
How to deactivate child lock on my Whirlpool 16 kg top loader WTL 1600 SL washing machine?
With the machine powered on, press and hold both the Rinse and Spin buttons down at the same time for 3 seconds.
12/10/2023 3:39:04 PM • Whirlpool... • Answered on Dec 10, 2023
Whirlpool Cabrio WTW6700TW1 skips wash cycle and stops after 14 minutes to oL
oL is an Overload error. Try running a cycle empty. If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
oL - Error Code - Washer - Product Help ' Whirlpool
https://www.google.com/search?q=whirlpool+cabrio+ol+error ..
12/9/2023 9:02:50 PM • Whirlpool... • Answered on Dec 09, 2023
Whirlpool AWM 1203. Washing machine keeps stopping.
Question edited for clarity, add maker, toss in some CAPS. Question moved to maker category. Likely needs a new controller board. https://www.google.com/search?q=whirlpool+awm+1203+stops+at+end+of+cycle ..
12/9/2023 8:04:30 PM • Whirlpool... • Answered on Dec 09, 2023
Video of changing the whirlpool duet frontloader door to the other side of washer opening?
I believe only the dryer has that feature.
12/7/2023 3:13:40 AM • Whirlpool... • Answered on Dec 07, 2023
Whirlpool cabriolet WTW7000DW0: lid locks, drum moves, add garment light intermittently on and off , no water fill, no cycle start start, eventually door unlocks on its own
have you unplugged the unit for 5 minutes to try and reboot the electronic control board yet ? If not unplug or turn the circuit breaker off for 5 minutes or more then give it power and see if it fixes it or it does the same thing. Best to you.
12/6/2023 11:31:23 PM • Whirlpool... • Answered on Dec 06, 2023
2answers
Whirlpool WTW5100HW0 F8E1
supply valves.
12/2/2023 6:55:20 AM • Whirlpool... • Answered on Dec 02, 2023
Whirlpool Clothes Washer Tub Stablizer Snubber Pad 358336 Logo
2 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
whirlpool duet sport loud vibration
  • Washing Machines
