20 Most Recent Taylor 1431 Digital Wireless Thermometer Questions & Answers
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
2/10/2016 6:54:59 PM • Taylor 1431... • Answered on Feb 10, 2016
2answers
yes there is a solution to stop the beep. Take a piece of cotton and put into ur ears..... simple
11/14/2015 2:53:43 PM • Taylor 1431... • Answered on Nov 14, 2015
No display for outside temp. after replacing batteries.
If the unit was workingg prior to the battery replacement, you must remove the battery and check on the terminals to the battery. Make that these are clean, the battery is good - test using a multimeter- and replace with the correct postion.Now if the earlier battery had leaked it could have damaged the internal board and if so you need to open to check if the board is clogged with the battery leak. If so try and clean the board.
5/5/2014 12:47:20 AM • Taylor 1431... • Answered on May 05, 2014
0answers
0answers
Need manual
Be the first to answer 6/27/2013 4:23:03 PM • Taylor 1431... • Posted on Jun 27, 2013Be the first to answer
0answers
Taylor Wireless 1542 remote batteries how to install
Remove the 4 small phillips head screws on the battery cover and it lifts off.When you replace the cover make sure the gasket (black rubber) is in it's groove.
7/24/2012 1:47:51 AM • Taylor 1431... • Answered on Jul 24, 2012
How to disable the alarm function on a Taylor weather station type wec-1502 ?
To disable the alarm function on your Taylor weather station type WEC-1502, follow these steps:
  1. Press and hold the "ALARM" button on the top of the unit until the alarm icon disappears from the display.
  2. Release the "ALARM" button.
  3. Press the "MODE" button on the top of the unit until the display shows the "CLOCK" mode.
  4. Press and hold the "ALARM" button again until the alarm icon disappears from the display.
  5. Release the "ALARM" button.
Your Taylor weather station should now be set without the alarm function.
2/26/2023 5:14:31 AM • Taylor Measuring... • Answered on Feb 26, 2023
2answers
Operating two transmitters for two base stations close together
their is no option of frequency channels , so units will probable interfere with each other
6/6/2022 11:58:02 AM • Taylor Measuring... • Answered on Jun 06, 2022
My Taylor we 1502 is showing HH in the outside relative indicator. How do I get it to recognize the outside relative humidity %? Thanks
If the outside temperature is currently displayed, there may not be anything wrong with the we 1502 sensor. The HH indicates that the outside relative humidity is above 95%; that is a limit of the sensor's detection/accuracy range. You could try moving your we 1502 sensor to a dryer area where it isn't exposed to rain/other falling water or wait until things dry out. I hope this helps. Please add a comment with the model for the base of your weather system for more information. The HH message applies to most Taylor weather systems. The manual for the Weather Guide Indoor/Outdor 1731 system is available here: http://ecx.images-amazon.com/images/I/71QBC5RdcNS.pdf . Cindy Wells
6/28/2021 4:56:04 PM • Taylor Measuring... • Answered on Jun 28, 2021
Taylor 1431 Digital Wireless Thermometer Logo
22 questions posted
Top Taylor Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Taylor Measuring Tools & Sensors
Most Popular Question
stop taylor 1341 digital thermometer
  • Measuring Tools & Sensors
