Taylor 1431 Digital Wireless Thermometer Logo
Diane Tolomeo Posted on Jan 14, 2012
Taylor Wireless 1542 remote batteries how to install
I can't figure out how to open the battery compartment on the remote sensor. It's such cheap plastic I'm afraid to play with it too much and break it. Anyone done this easily?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
508
Points
Remove the 4 small phillips head screws on the battery cover and it lifts off.
When you replace the cover make sure the gasket (black rubber) is in it's groove.
How to replace the battery
To replace the battery on a remote, you will typically need to remove the back cover of the remote to access the battery compartment. Here are the general steps you can follow to replace the battery on a remote:
  1. Locate the battery compartment: The battery compartment is usually located on the back of the remote and is typically held in place by a small latch or a screw.
  2. Open the battery compartment: Depending on the design of the remote, you may need to use a small flathead screwdriver or a coin to open the battery compartment. Some remotes have a latch that you can slide to open the compartment, while others have a small screw that you will need to remove.
  3. Remove the old battery: Once the battery compartment is open, you can remove the old battery by gently prying it out of the compartment using a small flathead screwdriver or a similar tool.
  4. Install the new battery: Insert the new battery into the battery compartment, making sure that the positive and negative terminals are oriented correctly. The positive terminal is usually marked with a + symbol and the negative terminal is usually marked with a - symbol.
  5. Close the battery compartment: Once the new battery is installed, close the battery compartment and secure it in place using the latch or screw.
If you are having difficulty removing the back cover of the remote or are unsure about how to properly install the new battery, you may want to refer to the owner's manual for your specific remote or contact the manufacturer for assistance.
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Cannot open remote battery compartment
Amazon.com: Customer Discussions: battery installation for remote ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jun 11, 2014 - As strange as it may seem to everyone else I cannot figure out how toopen the remote for my Kindle HD TV to put the batteries in.
Amazon Fire TV Stick: How To Open The Remote's Battery ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE
Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: ... Amazon Fire TV Stick: How To Open TheRemote's Battery Door.
Open Amazon Fire TV 2015 remote battery compartment ...
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M
Oct 6, 2015 - Uploaded by sfsilicon
I am not responsible for any damage to your remote. Proceed with caution. This video shows you how to open ...
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
2helpful
Replaced batteries, outsid temp. does not display
Remote not working
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
5helpful
Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
1helpful
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Top Taylor Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
