20 Most Recent Taylor 1525 Wireless IndoorOutdoor Thermometer With Hygrometer Questions & Answers
I've just been through this with my Taylor. My first mistake is that I put the batteries in the wrong direction... I corrected that and it only worked for a short time, then quit.. Ultimately, I had to get my multi-meter out. I found that one of my batteries was faulty.. Now, you have to remember that there are two AAA batteries in the main unit... and two of them in the remote that you place outside... Go.. You can fix it...
Taylor 1525... | Answered on Jan 16, 2013
yes, behind the cover, it takes 4 screws to remove
2 are easy but the other 2 are under the flip up stand
Taylor 1525... | Answered on Oct 24, 2012
www.taylorusa.com/media/IBs/1524_ib.pdf
Taylor 1525... | Answered on Dec 12, 2011
The Clock display is located at the top of the base unit's LCD screen. The clock has alarm and snooze functions.
A) Clock Setting
1. Press and hold the "SET" button on the back of the base unit for 3 seconds to enter Clock Setting Mode. The year digits flash in place of the clock digits.
2. Press the "+" or "-" button to change the year. Press "SET" to confirm. The month digits flash.
3. Press the "+" or "-" button to change the month. Press "SET" to confirm. The date digits flash.
4. Press the "+" or "-" button to change the date. Press "SET" to confirm. The Day/Month ("D M") or Month/Day
("M D") selection flashes.
5. Press the "+" or "-" button to toggle between Day/Month and Month/Day format. Press "SET" to confirm. A language selection flashes under the "DAY" icon to the left of the clock digits.
6. Press the "+" or "-" button to toggle between language selections*. Press "SET" to confirm the displayed language. Time zone offset digits flash in place of the clock.
7. Press the "+" or "-" button until the correct time zone offset** appears (-12 to +12). Press "SET to confirm the displayed time zone offset. "12 Hr" or "24 Hr" flashes.
8. Press the "+" or "-" button to toggle between 12 and 24 hour clock mode. Press "SET" to confirm.
The hour and minute digits reappear. The hour digits flash.
9. Press the "+" or "-" button to change the hours. Press "SET" to confirm. The minute digits flash.
10. Press the "+" or "-" button to change the minutes. Press "SET" to confirm. The hour and minute digits stop flashing. The clock is set.
Taylor Measuring... | Answered on Nov 04, 2019
Change the batteries. LCD displays will appear very dim and hard to read except at certain angles is the batteries are low.
Taylor Measuring... | Answered on Sep 07, 2019
Howdy! Good news... go to this site for detailed instructions...
https://fccid.io/WEC-1502/User-Manual/User-manual-2726076
if that fails contact the company 'customer support'.
Taylor Measuring... | Answered on Dec 19, 2018
First, I'm not a Taylor representative.
* Check your warranty. Call for support
* Contact; 1-800-289-0944
* WWW.taylorusa.com
*** The following is for information only.***
* Are you sure about the model "5212"?
* LED Meat Thermometer; https://www.youtube.com/watch?v=v6okAYWECvQ
* Manual (1487); https://www.wholesalepoint.com/documents/Taylor-1487.pdf
* Unboxing (1487); https://www.youtube.com/watch?v=SagK4czbaF4
* True Temp; https://www.youtube.com/watch?v=S9mLBcW2R_k
Aloha, ukeboy57
Additional (related) Information;
* Dial style; https://www.youtube.com/watch?v=OgrSqFR0x9o
* Brochure; http://taylor-enviro.com/media/lit/2014-ProKitchen-SellSheet.pdf
* Specs; http://www.lesman.com/unleashd/catalog/thermome/Taylor-dial-thermometers/tay_pockets.pdf
* Using meat thermometers; https://www.bhg.com/recipes/how-to/food-storage-safety/using-a-meat-thermometer/
* Calibrate; https://www.youtube.com/watch?v=gfx2zJP0QTw
Taylor Measuring... | Answered on Aug 18, 2018
In vigorously boiling water, it should read 212 (at sea level) or a little less, depending on your elevation - lid on or not. Maybe the water wasn't boiling fast when you got the 200 reading. Make sure the probe tip is not touching the pot sides or bottom.
Taylor Measuring... | Answered on Dec 30, 2017
Taylor 1525 Wireless IndoorOutdoor Thermometer With Hygrometer Logo
6 questions posted
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Taylor Measuring Tools & Sensors
Most Popular Question
need instruction manual
  • Measuring Tools & Sensors
