20 Most Recent
Espressione CA4865 Supremma Super Automatic CoffeeBeverage System Silver Questions & Answers
I am looking for a replacement for the outer
Espressione no longer has anything to do with this machine. Manufactured by Solac in Spain. Now sold only in Europe under different Model #. Neither will help you. I tried with mine. Only thing to do is try to get part from someone else's that is broken, or give yours up for parts. For either, I might be interested.
I have same unit. Produced by Solac in Spain. No longer sold in U.S. Solac won't help. I had leak out bottom of machine. Removed brew group and tightened phillips head towards front which was loose. This stopped the leak on mine. Hope it works for you.
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
