20 Most Recent
Espressione Caf? Retro Cappuccino/Espresso Maker - Silver Questions & Answers
I have a Cafe Retro
Sounds like you have a plugged line somewhere or dirty filter screen. Does the pressure stay the same? If it slowly goes down, then you have a leak somewhere.
I do not have a manual for this machine, but I will try and search for a service manual. But I do believe you have a plugged water pickup line or plugged water jet/spout
Espresso maker
sounds like you need to remove the coffee oils from the Brew Head Screen and filter basket which a decalcifier and vinegar will not touch.
Starbucks cleans theirs every night.
info:
soak the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover by www.urnex.com or dezcal.
Steam
Try to descale the machine first to see if that helps.
/Mirran
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
