SOUND Q SERIES
DUAL 6-OHM CONFIGURATIONAccommodating the rising trend of triple-subwoofer applications, Audiobahn’s Sound Q subwoofers come in dual 6-ohm configurations. This allows three Sound Q subwoofers to be wired in a 1- or 4-ohm operation. You now have the option to use a wider range of amplifiers to fit the needs of your specific application.
MULTI-CONNECT LUG LOCK TERMINALSAudiobahn’s patented Multi-Connect Lug Lock Terminals offer increased versatility in wiring multiple subwoofers to an amplifier or to another voice coil. Multi-connect terminals allow you to use single wire connections in each terminal rather than combining multiple wires into one terminal. This feature allows you to use a full 8-gauge wire in each terminal.
COMMON FEATURES
Dual 6 Ohm VOICE COIL
Multi-connect Lug Lock Terminals
The Link below should answer all your questions.
Also remember to try to keep the lengths of the jumpers the same. I would make all the connections inside the box then use the teminal block of the box to connect to the amp.
Keep in mind that you can only get 1 Ohm if you use 3 woofers.
Your configuration allows for 1.5 Ohm
http://www.audiobahn.com/Audiobahn06/images/tech/wiring/parallel_parallel_dual_6.pdf
Good Luck
