Question about AudioBahn Car Audio & Video
How do i hook up an Audiobahn a loom tenquiu woofer 800 watts
  • Alphanso Tee Feb 19, 2019
    Hi Mitch worley, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what ohms is each sub
4 Suggested Answers
uge44
Eugene Tetlow
  • 226 Answers
SOURCE: i dont know which wires
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Posted on Nov 20, 2008
Kristy Neff
  • 155 Answers
SOURCE: WHICH IS THE BEST AMPLIFIER FOR A ((AUDIOBAHN AWES15P ))WOOFER??
i dont ever get tired of saying it LOL A2300HCX audiobahn
Posted on May 11, 2010
Daveatwhips
Daveatwhips
  • 492 Answers
SOURCE: i have 2 audiobahn 12
OK. Sometimes manufacturers put two flat prongs to each of the positives and negatives of the voice coils. This allows for daisy chaining multiple subs to be easier. Here is how you want to wire your subs in the box.
From the positive post of the box to the positive posts of both voice coils (just choose one prong on each of them, you do not have to connect all 4 of them). So you will have 2 wires going from one post on the box to 2 posts on the sub. Got it. Not go from the negative post on the box, to both negative posts on the subs. Repeat this with the other sub. Now you can hook each channel of the amp to the box regularly pos of amp to pos of box and neg of amp to neg of box.
This set up is called parallel and will drop the ohms resistance of two 4 ohm voice coils to a 2 ohm load. You will get 2 ohms for each sub, thus connecting one sub to each channel. This will allow you to get the max power out of the amp or 150w RMS per your post. Hope this helps.
Posted on Aug 23, 2011
Ron Williams
SOURCE: can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Posted on Jul 30, 2012
I need to know what the recommended box spec for a audio Bahn dJones special edition 15 woofer 500 watts is trying to build a box for it
These subs are the (AW1251SE). Go to the Audiobahn website and look up the specs. I have included a hyperlink that will take you to the correct page. Find the model number and download the PDF. Inside the PDF file it will have every parameter listed, I already looked at it and made sure. It also has different enclosure options and gives the specs for each one.
http://audiobahn.com/index.php/help/tech-support/manuals/category/6-subwoofers.html
Aug 18, 2015 | Car Audio & Video
How do you hook up 3 12 inch woofers to an 1800watt audiobahn 2 channel amp to receive more depth in the bass?
Hi, im a retired installer so let me see if i can help you out. First, you need to get the impedance of your woofers. Next, you need to find out if your amp is bridgeable. That means you can make both channels tie together. Now here is your issue to consider. Running an odd number of woofers may not be the way to go because of your impedance. That being said, if you can get me the info above i can tell you the best way to set you up.
May 03, 2015 | AudioBahn Car Audio & Video
I have a 2 ohm stable watt amplifier with 2 audiobahn aw1251t wiring dual 4 ohm subwoofers, but theres no thump coming from the subs when i have it hooked up. Im sure the problem is the wiring inside the...
Generally there are 2 parts to this problem
part 1
input signal as these woofers are just subs remember to give them a low line in signal before the amp (see diagram) i like to use rca low pass crossover filters from harrison labs (see link)
part 2
is the wiring configuration of the 2 woofers by wiring them in parallel as shown in the diagram you reduce them to a 2 ohm load for your 2 ohm amp meaning you'll get max loudness and efficiency
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA Shipping is...
Oct 28, 2017 | AudioBahn Car Audio & Video
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Rear speaker wires
You don't give the year of your Navara, but the 2005-2007 ones do have a second small connector that probably carries the rear speaker signals. If you feel back from the connector, the wire bundle should split off a few inches back, and you can hopefully follow that branch to the other connector.
Aug 17, 2009 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
Wiring Option #1
Wiring Option #2
Nov 20, 2008 | AudioBahn Car Audio & Video
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Will this amp push my speakers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Mar 25, 2007 | AudioBahn A4401Q Car Audio Amplifier
Car Audio & Video Logo
235 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Professor_V
Professor_V
Alphanso Tee
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
