SOURCE: Audiobahn A 18001DT
the remote of amp. is not a ground it is a pos.+ 12 vlts look the back of your car stereo red the remote and conect to remote of the amp. if no sign remote of the car stereo conect to the 12 vlts of your bat.
SOURCE: audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
SOURCE: i play my music on low and it has bass wen i turn
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
SOURCE: bass knob for audiobahn a2300hcx, where can i get one
possibly try ebay maybe! i think the ABR is the same, most knobs on amps are the same unless smaller!
you need to have the switch set to LPF and then there is a level knob where you set the gain. Have it turned all the way down (counter clockwise) and then turn the system on and slowly turn the gain up until you find your desired level. It will sound louder when you're messing with it, but set it then sit in driver seat and make sure it's all good.
