20 Most Recent AudioBahn A2300HCT Car Audio Amplifier Questions & Answers
the ground wire u are using may be too small
AudioBahn... | Answered on Oct 09, 2013
are you ben kerr from carlisle? I've been looking for you. txt me 07731596368. :)
AudioBahn... | Answered on Apr 10, 2013
u can replace them with a little bit of sawder
it takes some itime but its poss
ible
AudioBahn... | Answered on Jun 22, 2011
  • Open the Amp up. Look for any black spots on the board. If it "blew" you should see a burnt electrical component, perhaps a RCA jack where the cords go. That's the first step in looking at a suspected "blown amp"... is to try and see if you can see what blew.
  • Let me know what you find. If the fuse is blowing just as quick as the power feed is connected there is a burnt part of the board and/or a component. I suspect a diode. They allow current one way and are what one may say a fuse on the board itself in the form of a component.
  • Let me know.
Tony
AudioBahn... | Answered on May 30, 2011
It will never work at 1 ohm for more than a few minutes. you may be able to run it at 2 ohms stereo and 4 ohms Mono but 1 ohms stereo may be too much for the amp to handle no matter what you do to cool it.
AudioBahn... | Answered on Mar 13, 2011
This indicates a possibility of a power supply issue, you may have to open up the unit and take voltage measurements to determine if the voltages are correct. In order to do this you will need a schematic diagram of the unit. Once you have the schematic you will be abor to tell which voltages are legitimate. I hope this helps
AudioBahn... | Answered on Feb 24, 2011
the rca's need to be plugged in from the radio to the amp. if not thee will be no signal going to the amp thus no sound coming out of t. you can get rca's from your local car audio shop or even big box stores like walmart or bestbuy. get a good set thats twisted and had good shielding around the wires. they may be expensive but heir worth it
AudioBahn... | Answered on Sep 15, 2010
Nope, sell it all on ebay. You shouldn't be behind the wheel anyways.
AudioBahn... | Answered on Jun 30, 2010
check your wiring's, there are two positive lines, one is directly connected to the batteries positive terminal and the remote positive is connected to the ignition's positive, and make sure it is properly grounded.
AudioBahn... | Answered on Jun 10, 2010
well if this is a factory radio it will need to get reset from a dealer to work with your vehicle
AudioBahn... | Answered on Jun 04, 2010
do you have signal going in? speakers hooked up correctly? speakers good?
AudioBahn... | Answered on May 19, 2010
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
AudioBahn... | Answered on May 16, 2010
check out audiobahn.com under tech support it will show you all the wiring diagrams
AudioBahn... | Answered on May 12, 2010
yep, they dont make audiobahn any more i think they still make other subs to one of them is DUB subs, ebay is the best place for me to find audiobahn, and for parts...
AudioBahn... | Answered on May 11, 2010
AudioBahn A2300HCT Car Audio Amplifier Logo
Popular Tags
55 questions posted
Top AudioBahn Car Audio & Video Experts
xxxxxx xxx
ADMIN Canada
ADMIN Canada
ray gallant
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AudioBahn Car Audio & Video
Most Popular Question
a2300hct car audio amplifier i have a au
  • Car Audio & Video
