20 Most Recent
Casa Vieja 52" Casa Endeavor Brushed Nickel Espresso Ceiling Fan Questions & Answers
Remote will not turn on or off light
I believe this fan is sold by a private lable on the internet. You probably need a new receiver which you'll have to get from the store that sales that brand.Google it.
How do I remove the glass globe on a 70" Casa Vieja Coastline Modern Contemporary fan?
To remove the glass globe on a 70" Casa Vieja Coastline Modern Contemporary fan, you need to follow these steps:
Turn off the fan and wait for the blades to stop moving.
Locate the screws that hold the glass globe in place. These screws are usually located at the base of the globe.
Use a screwdriver to loosen the screws. You may need to turn them counterclockwise to loosen them.
Once the screws are loose, gently pull down on the globe to remove it from the fan.
If you have any trouble removing the globe, please refer to your user manual or contact Casa Vieja customer support for assistance.
Where is the seasonal direction switch located?
Question edited for clarity and correct model name tempura to Tempra.It is one of the pull chains. If it has two chains, one if Fan On/Off and three speeds and the other chain is Reverse Direction. If it has a third chain, that is Light On/Off.Product descriptionCasa Vieja Tempra ceiling fan in a oil-rubbed bronze finish. 3-speed reversible fan. It has 5 oil-rubbed bronze finish blades that span 52" with a 12 degree blade pitch. Opal glass light kit included two 13 watt CFL bulbs. Cap included for non light kit usage. Comes standard with a 4" downrod. Dual mounting hanging system allows for it to be hung from a downrod or flush with the ceiling.- Oil-rubbed bronze finish 3-speed motor; Lifetime motor warranty.- Five matching blades; opal glass light kit includes two 13 watt CFL bulbs.- Pull chain operation.- 52" blade span, 12 degree blade pitch.- 4" downrod included.- 153x12mm motor size.- Fan height 11.6" ceiling to blade (with 4" downrod).- Fan height 16.6" from ceiling to bottom of light kit (with 4" downrod)...
Casa Vieja fan service requested
this is question forum. manufactures do not read it. call the number in your manual and ask for service, but it may cheaper to replace the unit, if you have to pay the labor to disassemble and remove remove and reassemble and reinstall unit.
Where do I find a 12" down rod to match the 54" casa Vieja lynx fan?
You may be able to find a 12" down rod that matches your 54" Casa Vieja Lynx fan by contacting the manufacturer directly or checking their website for available parts and accessories. Alternatively, you can check with home improvement stores or online retailers that specialize in ceiling fans and their accessories. It's important to ensure that the down rod you select is compatible with your fan model to ensure safe and proper installation.
Two fans work with one remote
Turn the power off to the fans at the breaker. Double check the DIP switches on each fan head from a written note. Then check the DIP switches on the remote. Then remove the batteries from the remote and count to 50 and re-insert them. Turn the power back on to the fans.
Does Casa Vieja make down rods for its fans over 72 inches long?
177 inches
What sizes do Downrods come in?
Standard ceiling fans include a downrod ranging in length from
3 inches to 6 inches, which is suitable for standard size rooms with a ceiling height of 8 - 9 feet. However, fan downrods can range up to 177 inches depending on the manufacturer.
Apr 26, 2017
Casa vieja fan will not sync to remote
Ah, I forgot about synching. The remote and the fan head have small DIL switches that have to be set the same settings. They do this so you can have multiple fans in your home and you can turn them on and off independently, or in a large lofted living area, you could have two that work together.
