There are small DIP switches in the fan head and small switches in the remote. The head and the remote have to match. If you have two remotes, you can set fan heads and remotes to different channels. Video shows it.
https://www.youtube.com/watch?v=hmQQjXEWuQw
How to Set the Dip Switch on a Ceiling Fan - HomeSteady
https://homesteady.com > how-to-set-the-dip-switch-on-...
Jul 21, 2017 - Open the battery compartment lid on the back of the ceiling fan's remote control. · Push the "Dip" switch up or down, as per the instructions ...
How to Set the Dip Switch on a Ceiling Fan - Home Guides
https://homeguides.sfgate.com > ... > Home Maintenance
Remove the receiver box cover to look at the dip switch settings. You will see four sliding buttons. The button configuration must match the remote control's ...
SOURCE: Casa Vieja Probe II Ceiling Fan
look on the side of the canopy there should be a slide switch. if moving this switch has no effect, then either the switch is faulty or the connections to it may have fallen off.
SOURCE: casa vieja probe ceiling fan
one of the wires had disconnected and this seemed to cause the problem.
SOURCE: Casa Vieja Intrepid Remote Control Sensing Problem
you need the same sensors in the remote as the one ur using now the old sensors will not work
SOURCE: Casa Vieja Fan
Call 1-800 782-1967 Lamp's Plus - ask for Lance at extension 4565. Just bought a flywheel for a 52" fan. Part number 85411.
SOURCE: Remote Control
I had the same issue. I had to replace the remote control reciever located on the fan and that did the trick.
