20 Most Recent
KitchenAid KGSK901SSS Gas Range Questions & Answers
Self clean and oven light
The latch is stuck halfway! Take your finger and push the latch all the way to the right until the oven light goes out. Now hold it there and press the self clean button. Let it start up for a few seconds then hit the off/cancel button and let go of the latch. It should hear it made a winding like sound as it goes back to it starting position.
When I start the oven, the stove top ignitors
In your model, maybe everything sparks when one item is turned on. That might not be a problem.Two possibilities: The spark board is defective or the gas valve is defective. Each one cost about 150 each. The gas valve is the one that we usually see go first.Ohms out the gas valve: middle wire to wire on the left; middle wire to wire on the right. If the values are not close or one reading shows 'open' then replace the gas valve.
Gas covection oven temperature does
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
I have a kitchenaid gas
Sorry to read about your problem, I hope this helps you out.
yes, you can heat them up just a little, or use the cold directions on the spray can..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
