20 Most Recent
Epson WorkForce WF-2530 All-in-One Printer, Copier, Scanner, Fax Questions & Answers
How to install new ink cartridges and how to take out old ink cartridges
If you have some cartridges that aren't empty, first make sure that the printer is on. Then press the Menu button and navigate to the Maintenance menu then select Ink Cartridge Replacement. Press OK. Make sure that the document cover is closed then lift the entire scanner unit (grip it on the sides). If the cartridge carrier moves, wait for it to stop.
Then squeeze the tab at the back of a specific cartridge and pull it straight up. (Have one finger on the tab and another finger or thumb pinching the opposite side of the top of the cartridge.) Prepare your new color cartridge by shaking it 4-5 times then open the bag. Remove the yellow tape from the cartridge without touching any other parts of the cartridge. Then insert the cartridge into that slot and press down until it clicks. Repeat this for the rest of the ink cartridges.
Finally, lower the scanner unit and press OK on the keypad to exit the maintenance mode. Wait for the printer to do its ink system test routine. Cancel any print or scan jobs that were in progress before you changed the ink.
I hope this helps. Pictures to go with the above description are in the user's guide starting on Page 177. It's available here:
https://files.support.epson.com/pdf/wf2520/wf2520ug.pdf .
Change print size
just scale to a4 from print dialog box appear on right bottom side
other wise delete all prints and restart printer and computer then try again it comes to actual sizze
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
- Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
- Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
- Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
- If the error persists after trying the above steps, you may need to replace the print head.
- If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
