20 Most Recent Panasonic KX TG2237S Cordless Phone (KX-TG2237S) Questions & Answers
use this link to get the phone user manual. In page 28 it has the details of the Caller ID's. Post us back if your problem not solved
Panasonic KX... | Answered on Jun 10, 2010
Most likely the microphone hole at/near the bottom of the phone is clogged with dirt. If you are able to, then dissasemble the handset, find that opening and clean it out. If you're not that brave, maybe try cleaning the hole with a toothbrush. Don't stick anything into the hole as you may damage the microphone. Hop this helps!
Panasonic Lands... | Answered on Sep 17, 2020
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Panasonic Lands... | Answered on Sep 03, 2020
Something not quite right with that model number. If it is connected to a base station, it is the model number of that you need not the model number of the handset. you also need all the letter and numbers correctly spaced and capitalised, Kxtsc909cid is not the same as KX-TSC-909
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00D1Wp9LMoO1pa4ghRuxlHeRiF0mw:1598720691167&q=manual+of+Panasonic+Kx+Tsc+909
Panasonic Lands... | Answered on Aug 29, 2020
The message indicates the base part of the phone is not receiving power.
Panasonic Lands... | Answered on Aug 27, 2020
Could be phone Co. problem
Based on the documentation for the KX-T76XX phones, you can cancel the Call Forwarding by picking up the handset of your KX-T7630. Then press the FWD/DND button. Next press 0 to cancel all call forwarding. See page 17 of the manual here: https://www.ask-tsc.com/pdf/KX-T76xx.pdf . (You can also select to cancel call forwarding for external or internal incoming calls separately, if needed.)
If pressing 0 does not work, did you lock the extension? See page 18 for information on unlocking the extension. If that fails, contact your phone system administration. As far as I know, there is no global reset option available to users of an extension.
I hope this helps.
Panasonic Lands... | Answered on Aug 25, 2020
There are dozens of models and yours is a mystery to us :>)
Google
make model manual
my guess is that yours has been programmed NOT to make outside calls.
Panasonic Lands... | Answered on Aug 02, 2020
Request the diagram directly from Panasonic.
Panasonic Lands... | Answered on Jul 25, 2020
Hi dear Lavon Bonar:
RE: Unblocking phone numbers on your Panasonic landline:
Dial *60 to access blocked numbers:
Your Selected Call Rejection Service is probably now ON;
To TURN OFF Call Rejection Service, dial 3.
OR
To REMOVE ALL blocked entries Dial 08*
That's it. Glenda Gammel 9/21/2017
Panasonic Lands... | Answered on Jul 21, 2020
Panasonic KX TG2237S Cordless Phone (KX-TG2237S) Logo
Popular Tags
1 questions posted
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
caller id stopped working
  • Lands Phones
