20 Most Recent
KitchenAid KWCU205HSS Kitchen Hood Questions & Answers
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
KitchenAid wall mounted stainless steel stove hood (model KWCU285HSS)
Hi ahev you took the unti off the wall as you need to do this to be able to acess the internal electrics of the unit.
Did you fit it on the wall or get somebody else to do it.
Their is three screws holding it to wall one either side and one up towards the top let me know if you understand what im going on about
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
