20 Most Recent
Piaget Upstream GOA28008 Wrist Watch Questions & Answers
My watch is not moving . I want to know do I need
Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
Watcmaker has advised the circuit in a piaget
once the circuit is cut the watch stops and leaves ur 2 options. o
1 replace
2 the make a circuit glue which coats the whole circuit and most cases restores power, this is very inexpensive. they dont recommend cause they want to sell parts
Sector adv 1000 manual
ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH.
NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position.
1) Set the crown at the normal (in) position.
2) Push the B button twice.
3) Pull out the crown to the 2nd position (fully out).
a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position.
b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position.
4) Push the crown back in to normal position.
QUICK-SET OF THE CALENDAR DATE
With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date.
4/25/2024 5:30:35 PM •
Watches
Answered
12 hours ago
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
