Question about Piaget Watches
How do you set the time on a Piaget dancer quartz
Posted by Dan queen on
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
How to adjust the correct time of ajanta quartz ODC-120
move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
Oct 14, 2013 | Watches
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: [email protected]
Feb 04, 2011 | Timex Expedition 43892 Wrist Watch
Need to find the value of an old Piaget watch that I inherited. The numbers on the back are stamped as follows: 6801 E 10 228916 the band says Piaget 750 thanks Rani
mcdevito75 Here, Hello Rani, Piaget, a FINE watch, even without seeing your Piaget watch were speaking $250.00 and above. Shop a couple of jewelery shops in your area, they will be glad to help. NOTE-- unless you relly know, DO NOT CLEAN THAT PIAGET YOURSELF as any Damage could and would leesen it"s value. By cleaning I mean even polishing the band, have a small watch repair shop in your area care for your Piaget watch.
Jul 07, 2010 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Where can I get a 333 battery
In England
http://cgi.ebay.co.uk/5-Watch-Batteries-Renata-313-323-325-333-354-set-3_W0QQitemZ270535998336QQcmdZViewItemQQptZUK_Jewellery_Watches_WatchAccessories_SpareParts_SM?hash=item3efd33bb80
In USA - none listed on ebay, except for international (from England).
The 333 is quite an unusual battery, in that its one of only three with no other entries on a cross reference chart (i.e. not widely made).
Feb 24, 2010 | Piaget Watches
Ferlie
What is the question?
Make and model of watch needed as well!
Feb 19, 2010 | Piaget Dancer GOA24001 Wrist Watch
Watcmaker has advised the circuit in a piaget ladies smallquatz watch requires replacement can you advise please
once the circuit is cut the watch stops and leaves ur 2 options. o
1 replace
2 the make a circuit glue which coats the whole circuit and most cases restores power, this is very inexpensive. they dont recommend cause they want to sell parts
Oct 09, 2009 | Piaget Watches
Watches Logo
214 people viewed this question
Top Piaget Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Piaget Watch Expert? Answer questions, earn points and help others
