Question about Piaget Watches
I have Piaget S/N 79395 18K Gold with 50 small diamonds in the bezel and gold face. Where can I find information on this particular watch and it's history?
Posted by NCav on
5 Related Answers
Anonymous
SOURCE: Real or fake?
try open it ,original tag heuer has a tag heuer swiss made engrave or printed inside your watch.
Posted on Feb 21, 2008
micromaster
micromaster
  • 3614 Answers
SOURCE: Need replacement leather part of strap for 18K gold Tag Heuer.
ask them here..
Customer Service
Mon. - Thur: 9:30 AM to 6:00 PM
Fri: 9:30 AM to 3:00 PM
Phone: (877) 834-1434
Phone: (212) 924-9925
Posted on Jan 15, 2009
Jackalltrade
SOURCE: BULOVA WATCHES
Most watches have the gold content engraved inside tha back cover. Open carefully!
Posted on Apr 21, 2009
Anonymous
SOURCE: History & battery number
377 ETA
Posted on Sep 18, 2009
Anonymous
  • 8 Answers
SOURCE: manual for rosra watch - man's - #8637G
Search on the internet for the manual, or if you cant find one, just ask me and I will try to find one for you!?☺
Posted on Oct 16, 2009
What is it the value (never been worn)
Bulovas are not high end luxury watches nowadays (they actually were, up to the mid-twentieth century). A modern quartz Bulova is just another mid to upper-mid level quartz wristwatch. Unless you know someone willing to spend some bucks just to have a gold and diamond watch, the value, especially with the price of gold now, may be in the metal, especially since it's 18K; the majority of gold watches are 10K or 14K. The diamonds are likely not very high quality, although they will be real. You should have a jeweler look at it. He will be able to give you an idea what the gold and the stones are worth. Unfortunately, as a watch, Bulovas just don't have much intrinsic resale value nowadays, not like a Rolex, Tag Heuer, Breitling, etc. would have.
Aug 06, 2014 | Bulova Watches
Purchased a new 18k gold bezel to replace the bezel that has the gold worn off.
whats the problem are you trying to fit the new bezel? you will also need to ensure the bezel retention spring is with the bezil
Apr 10, 2014 | Tag Heuer WAF2110.BA0806 Aquaracer...
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Hi, i was caught in a thunder shower and since then i have moisture cloud under my face dial of the watch.please guide me to remove the moisture cloud . a.jarrahian
Best thing to do is remove the back and let it air dry for a few hours or until the cloud is gone, but it means your back or stem gasket needs replacing. You can use a hair dryer to speed the process. Keep an eye on the heat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dwayne_1bb1479309103b95
Oct 25, 2010 | Bulova Diamonds in Stainless Steel Or...
I have an old (1991) Corum Admiral's Cup watch and need to remove some links. How do I do that? Thank you for your time.
mcdevito75 Here, You"ll need a special toll called a link remover tool, available on ebay, however if you"ve never done work or this particular work on watches, your best bet is too find a small watch repair shop in your area for the link/s removal.
Sep 01, 2010 | Corum Admiral Cup 18K Yellow Gold Blue...
Second hand is moving at 4 sec incremants not second by second
This is low battery warning. Replace the battery and the watch will tick as new.
Rate me, please
May 19, 2010 | Ebel 1911 18K Gold Diamond Bezel Stainless...
What do the number on the back of the Geneve Diamond ladies watch mean.
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
Apr 29, 2010 | Geneve 14K Diamond Cut Gold Face Watch...
Can I remove the back of my bertolucci watch myself and replace the battery?
The method of removing the back of a watch varies from make to make. Often the question is how can I get it back on!
Unless the watch has an obvious battery cover (a small round cap which can be screwed off), it is much safer to take it to a watch shop to replace it for you.
They have all the tools, a stock of batteries and will will do the job a few minutes.
Jan 24, 2010 | Bertolucci Vir Mini Steel and 18k Gold...
Watches Logo
32 people viewed this question
Top Piaget Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Piaget Watch Expert? Answer questions, earn points and help others
