20 Most Recent
Dell Inspiron 1721 (dndwna2_5) AMD Turion 64 X2 Mobile Technology TL-60 (1MB/2.0GHz) 320GB/1000MB PC Notebook Questions & Answers
How to network
You need to go to the microsoft website or use windows help. If you come accross a certain problem we can help but to walk you through a whole networking process is a little much. Though it is pretty self explanitory. Set up all the computers the same Wired and wireless will be different of course but not too much jst a couple extra steps for the wireless is all. Let me know if you get any questions
My dell inspiron 1721 amd athlon dont have video
<P style="MARGIN: 0cm -6.4pt 0pt 0cm" class=MsoBodyText2>You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: - </P><P style="MARGIN: 0cm -25.7pt 0pt 0cm" class=MsoNormal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><A href="http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen" target=_blank>http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen</A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
When I use the external monitor S-video port on my
Okay. For Windows Vista OS.
Go to Control Panel.
Under the Control Panel Home, select Additional Options at the bottom right of the list.
Click on Appearance and Personalization:
At the top right corner of the dialogue box, under Personalization, select "adjust screen resolution"
This will bring you to display settings:
Click the button that says "identify monitors" As each is displayed, it will present a number for which is the default or main monitor (1 or 2) 1 is the main monitor.
To change the external to the main or number one monitor: simply drag the #1 monitor to the left side (if not already there) If it is, you'll want to set the external as the default:
Do this:
While in Display settings, if the external is the #1 monitor, make sure to check the box for "extend the desktop to this monitor" and "this is my main monitor" for the external display. This should switch all settings to the external monitor.
Also, make sure the the resolution is correct for the size monitor you have. For a 20" (such as mine, external Dell monitor) the resolution is at the highest (1920 x 1080).
Also make sure it reads (to the right of that) "highest 32 bit). If this is not an options, make sure you're adjusting the external monitor and not the laptop screen. Otherwise you may need to upgrade your video card.
You should not need to do this though.
After you have set this, go to Advanced Settings and select Monitor. You will see at the top, a list of two monitors; your external with it's brand and name - and the laptop screen type and name. Select the external monitor name: Click on properties, drivers and Update Driver, then select to Automatically search online for driver.
Please let me know if you need further assitance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
My Inspiron 1721 shuts down on its own
THE PROBLEM IS WITH THE SETTING IN THE COMPUTER PROGRAM, BASICILY YOU ARE TYPING FASTER THAN THE COMPUTER CAN HANDLE AND I KNOW BECAUSE MY MOTHER CAN TYPE 90+ WORD A MINUTE WITHOUT MAKING ANY MISSTAKES.
*******************************************************8
***************IMPORTANT*********************
YOU ARE TYPING FASTER THAN THE COMPUTER CAN STORE IT SO IT SHUTS DOWN SO IT CAN SAVE WHAT YOU ARE WRITING, YOU MAY BE BE ABLE TO CHANGE THE SAVE TIME FOR YOU DOCUMENT FROM 15 MINUTES TO 2-5 MINUTES, THIS MEANS THE COMPUTER WILL SAVE THE DOCUMENT EVERY 2-5 MUNUTES INSTEAD OF 15 MINUTES, BUT YOU REALLY NEED TO CHANGE THIS SETTING AND THIS IS GOING TO BE UNDER THE ***REGEDIT ***OPTION
A PROGRAM OF WORD OR MICROSOFT ADMINSTRATER MAYBE ABLE TO HELP YOU
BUT NOT ME.
MSCONFIG MAYBE ANOTHER OPTIONS YOU CAN LOOK INTO.
YOU MAYBE ABLE TO GO ONLINE AND JUST ASKED THE WORLD HOW TO FIX THE PROBLEM AND SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEM.
EXAMPLE:
TYPING TOO FAST AND COMPUTER SHUTS DOWN TO SAVE DOCUMENTS
ENTER
THIS IS WHAT I PUT IN ON THE ADDRESS BAR AND GOT 41,000+ HIT OR ANSWERS TO OUR QUESTION.
RODGANDYSR
PS YOU CAN ASK.COM, ABOUT.COM, YOU TUBE, ZABBA SEARCH, WIKIPEDIA, ETC...
Dual Monitors Keep switching sides when I turn off computer
try installing the latest drivers from support.dell.com
and use the ATI Catalyst software to set screen options instead of Windows (or vice versa)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=22&l=en&s=dfh&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_PM_1721
Charger for E1705 beeps and no green light
You are describing a classic wiring short circuit. Either the cables of your power supply or the jack on the laptop itself are damaged and need to be repaired or replaced as soon as possible to avoid permanent damage. There is no logical reason it would work only in certain outlets, that is probably just coincidental to the way you have the cable running while plugged in to each outlet.
Your power supply has two cables, the side leading to the AC outlet is removeable and easily replaced but the side leading to the laptop's jack is not. Start with the AC plug. Leaving everything from the 'brick' to the laptop in a stable position, gently flex the AC cable until you see evidence of the short (usually a break in the wire, possibly chewed by the dog or snagged on the edge of a desk). If so, replace the AC wire. If not, try the same with the laptop side of the brick. If so you usually should replace the entire power supply unless you are real handy with a soldering iron.
If moving the position of the two power supply cables doesn't identify the short, you must suspect the laptop's jack of being loose. This is worst of all because the laptop motherboard has to be removed to gain access to resolder the jack, a professional job that will run probably $100.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops:
Inspect and clean the air vents and fans
Restart the computer
Update the BIOS and Chipset driver
Download and install Microsoft Windows updates
Run a hardware diagnostic test
Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops)
Improve efficiency to reduce heat
Perform a Windows System Restore
Restore the computer to factory defaults
I want to delete my shtyle.fm account plz help me to delete acoount permanently
I don't know its solved or not but here's the method. Step 1 : Login to your profile of shtyle.fm Step 2 : Move your cursor to the "you option "or "your profile option". Step 3 : There, You will see the link of "Account Settings". Step 4 : Click on that link and you will see "Delete profiles and friends" Option There. Click on it. Step 5 : After that you will see the information that why you should't delete the account and bla bla bla. Step 6 : Just click on the continue button. I highlighted the link in below given image. Click there. Step 7 : Now you will see the box where you can enter the reason why you want to delete your shtyle account and profile. Enter reason or leave it blank and click on delete option. That's It. Your account is deleted. When you try to login with the same credential again you will see this. If you see below given error then your account or profile is deleted.
Source : Youshouldlisten.com
