Kenmore 95042 / 95044 Electric Kitchen Range Logo
Anonymous Posted on Jul 29, 2011
Kenmore stove 790.90102,,,burner switch # 318220001/obsolete=has 6 wires attached,,,,replacement switch #318293811/has 5 wire connectors,,,,,i have 1 wire left over?? do i splice it somewhere?? help if you can, thanks,,,bill
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Jul 29, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636861
Points
7414
Hello Bill,
i have a few questions please reply with answers
1) on old switch what are the markings,normally their P, L1, L2,H1& H2,is the other marking H3?
2)was the old switch your replacing for a select a burner size where you could select just the inner small segement of the burner to come on or with another selection the entire burner would heat?
3) what are the marking on the new switch,i suppose their P,L1,L2,H1&H2?
4) do all old switches have 6 wires or are 3 of them 5 wire and only the one your replacing 6 wires
Gene
Testimonial: "prompt"
  • bmklg9ds0g Jul 31, 2011
    Hot summer day is about to,Open the wardrobe is not yet found love after
    another the right clothes? So, also waiting for? Immediate action bar!
    Welcome to {http://www.famalegoods.com } sure you will find what you need.
    Moreover, the company has a good reputation, product quality standards,
    at reasonable prices. Over the years, has been well received by overseas
    friends for their support. Therefore, please rest assured purchase.
    ++++http://www.famalegoods.com ++++++++++
    Best online store
    Best quality, Best reputation , Best services
    ---**** NHL Jersey Woman $ 40 ---**** NFL Jersey $ 35
    ---**** NBA Jersey $ 34 ---**** MLB Jersey $ 35
    ---**** Jordan Six Ring_m $36 ---**** Air Yeezy_m $ 45
    ---**** T-Shirt_m $ 25 ---**** Jacket_m $ 36
    ---**** Hoody_m $ 50 ---**** Manicure Set $ 20
    ---**** handbag $37 ---**** ugg boot $43 ---****
    ---**** sunglass $16 ---**** bult $17 ---****
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 • Ovens
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
    • 2
    • Sponsored Links
    • 3
    • 4
    • 5
    • 6
1helpful
Hiya:) I have a kenmore electric stove model #362.922123Q1 w/a bad burner in it and i have replaced the burner and the receptacle to no avail:( can someone tell me the next step in the diagnostic...
Having replace those two parts the switch is bad,if you have a multimeter you can check the switch by setting the meter to the ohms setting and TURN OFF BREAKER TO THE STOVE OR UNPLUG access the switch by removing the back panel and set the switch to the HIGH setting ,then remove the wire off marked H1 and L1 and check for contuninty by placing the meter leads on those two terminals,then reinstall the wires on those and remove the wires off of L2 andH2 and check for contuninty there, if no contuninty on L1 to H1, or L2 to H2 then the switch is defective
the part# for the switch for the large burner is WB24T10027
the part # for the switch for the small small burner is WB24T10022
2answers
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
I am 98% done disconnecting the electric igniter on my GE stove. the last wire is connected to a green square thing and I cant figure out how it comes apart
the square green thing you are describing is the limit switch that controls the burner heat range those wires and connected in with a release pin that takes a ice pic or eqivalent to release the wire theres a small hole to stick the pick in and then slide the wire out! however some units have a perma soldered or crimped attachment to the wire and you have to replace the limit switch with the burner assembly or cut the wire and use a connector to reassemble
Oven wont work,stove (burners work fine E1, f5 error codes
HI. this is a self clean latch malfunction code.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
3helpful
One of the burner does not work on my electric Kenmore stove.
the eazy answer is its the burner.i only say that because on most service calls with your complaint it dose indeed end up being the burner.but before i come to that conclusion i do check the out put of that burners switch.if has 220 volt output then its the burner,even tho if you look at the wiring diagram it will show a limiter before it gets to the burner but that part is built in to the switch and is not replacable on its own.so then use volt meter take a look at your wiring diagram .look on that diagram and decide which wires are leaving the questioned switch that controls your bad burner .place your probes on those wires again if reads 220 volts replace the burner. i hope this helps .God bless ,tom
2helpful
Stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
