Depending on the Current opering system you are using, you are able to change these settings within windows. I have included the instructions below for your convenience: Under System startup, you can change the Default operating system between Windows 7 and Vista. If you have installed any other OS, you can change between those settings as well.
This is for Windows 7
Go to Control Panel Home (Start -> Control Panel) -> System and Maintenance -> System.
On the left side pane, under the Tasks, Click Advanced System Settings.
Click Settings under Startup and Recovery.
Click OK and the next time you start your computer, the boot order should have changed. You can also change the time duration for which it shows to change the booting OS.
I hope this has helped
While on Bootup do these shortcuts. I don't know what OS you have so on bootup try whatever one your OS is.
Dell XP = Ctrl+F11
Dell Vista = F8
Here is the support page for full info:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?&docid=DSN_353562&isLegacy=true
Note: Kindly back up all necessary documents before starting restoration as it would be deleted.
Make copies of all things on your PC you want to save, such as photos, documents and other installed programs. Resetting your PC to factory settings will erase all data on the hard drive. It will erase anything that you installed on your computer after you received it.
Restart your computer.
As the computer is turning on, you will see a blue bar that says "Dell.com" across the top of your monitor. At this time, press the Ctrl and F11 keys simultaneously. If you wait too long, you will miss the opportunity to do this and will have to restart your computer again.
Click the "Restore" option when the next screen appears.
Click "Confirm." The PC will begin its resetting process. This process takes approximately 10 minutes.
Click "Finish" when the process is complete. Allow the PC to restart itself. Do not restart it yourself since it needs to run through its boot program.
Click "Yes" to allow the computer to restart. When it does, it will be at original settings, and you will see the "End User License Agreement" screen. Click "Next." The System Restore screen will appear, and the computer will do another restart.
Once it does another restart, click "OK." You have now reset your Dell desktop to factory settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
