Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Aug 31, 2008
Zenith project color tv advanced video imagining
52in. zenith projection color tv has a continuos red tint. I can't chnage it and I would like to know how to fix it. It is a 1995 model and i would like to know the cost to fix it. Thank You, Michaelin
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
157
Points
I will tell you but it will cost you. Choose one of my assistance plans at a nominal fee. Sincerely, Michael
Green tint on picture. Cant adjust with tint or color from menu
My rear projection was doing the same thing. I have a mitsubishi and went into the video/audio set up. When I clicked on video it brought up brightness, tint, color, etc... Not sure if yours is set up the same.
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
My projection tv lost its blue tint
Hi
Thanks for using FixYa. Usually this happens when the Light Engine has gone bad, and I should say this is a common issue with Projection TVs. There are three tubes/mini LCDs inside your TV- green/yellow, blue and red. When the set heats up over time of usage the screens tend to break resulting in leaking color everywhere. The cost to get this fixed by a professional should be around $300 depending on the parts that needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2helpful
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
I have a zenith projection tv model # PVY4665
I have Zenith D.V.D V.C. R. Recorders The v.c.r. is working the D.V.D. I put Memorex D.V.D read no D.V.D i put Sony D.V.D REAd no D.V.D i like why no working The model no XBR 716 120-60 hz 24w Service no X br716 Ul File no E 225515
A new HD box from dish network has caused a problem with red tint
Call the dish network as they will fix you up for free rather than lose you as a customer.
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
2answers
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
2answers
Color problem
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Hitachi 52 projection tv
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
