Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television
Problems with Hitachi 50V710 50 in. Rear Projection HDTV-Ready...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Hitachi 50V710 50 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television RSS Feed
View More Results for Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television RSS Feed
Answer
Hitachi model 50V710 has continuous blinking blue light; no tv picture; no sound.
Answer
I hooked my DVD player up to the input 1 (using red, white and yellow cable) and had no video, but... (More)
Answer
We have a 60inch with the same yellow streaks in the picture. We send our TV to an authorized... (More)
Answer
After 15 minutes the tv turns off, goes thru a sreies of quick flashes of the blue power light, then... (More)
Answer
When viewing my 50" Hitachi V710 Rear projection TV, I have noticed recently that there is a... (More)
Answer
tv was working earlier but now there's no picture. Picture will not come on even after turning off... (More)
Find a Manual
Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Hitachi 50V710 50 in. Rear Projection HDTV-Ready...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Hitachi 50V710 50 in. Rear Projection HDTV-Ready Television
Key Features
Screen Size
50 inch
Display Format
720p (HDTV)
Digital TV Standard
HDTV-Ready
Projector Technology
LCD
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
Proprietary
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 2 · Audio (RCA) x 4 · RF x 2 · 1 x RS-232C · HDMI x 1
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Screen Text
OSD Languages
English · French · Spanish
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
16.38 in.
Height
35.5 in.
Width
54.63 in.
Weight
114 lb.
Warranty
Overall Warranty
1 Year
Hitachi Contact Information
Main support number1-800-448-2244
Support FAX1-309-589-7689
Email supportsupport_usa@hitachigst.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
