First turn the wireless on.
Then go to Start > Settings > System > Asset Viewer and look for "Wireless LAN" near the bottom of that list. Click on the + which will open the information tree out and show you the MAC address.
That depends on whether you are using mac address filtering or not. You'll need to put the modem password into the phone once. If you are using Mac address filtering, then enter the phone's mac address onto the modem list first.
Well, when it comes to ip addresses, you must either turn off dhcp (which automatically gives out ip addresses to devices joining the network) and assign static ip addresses to each individual device on the network, or simply decrease the number of ip addresses your router's dhcp gives out by narrowing the dhcp range. Blocking ip addresses is an ineffective way of preventing access to the network. MAC Address filtering, on the other hand, is much more secure. Usually this is locating under Wireless - MAC Filter in the router's configuration page. When you get to the menu, you usually have the option of making an allow or deny list. If you are having problems with unknown devices, I would go with allow only option, and enter each of your device's MAC addresses. The one main problem is that you will have to do this every time a new device is added to the network, but it makes the network much more secure.
should be an option in the console (in browser go to 192.168.0.1 or 192.168.1.1, etc)
MAC Filtering just means that you can set up a set of MAC addresses (Machine Address) of units you want to be able to access your network. If you didnt set the MAC of a unit it will not be able to join the network. So mac filtering is a way to limit connection with your network.
I never figured out how to reset the machine but I figured out what I messed up on. I accidentally toggled the MAC address RX Auto to off. This means you must specify the MAC address of the machine you want to access it. This is why my computer could not find the printer. I went into the settings on the machine and changed it to auto and it works great.
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
What about your desktop pc? Have you checked the services on it to make sure it is not broadcasting DHCP? Also, think about switching over to Stealth Mode (Non-broadcast SSID) instead of MAC filtering. MAC filtering can be cummbersome and if it is just you, then do away with it.
Have you tried a soft reset or hard reset yet P ?
How about a ROM update ?
Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit
Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
