Listed below are some basic steps to help restore sound to your computer. This troubleshooting guide assumes that your computer has no sound at all. Update Software: Many sound problems are resolved simply by downloading the latest version of the Windows Media Player and/or Internet Explorer directly from Microsoft to use as a baseline test. If you are using Microsoft Media Player, it may be useful to check for any recent updates. To do that, just start the Media Player, click on "Help", then click on "Check for Player Updates..", and it will automatically download any updates. Or, you can download the latest Microsoft Windows Media Player for both PCs and Mac for free from: http://www.microsoft.com/windows/windowsmedia/9series/player.aspx Also, since old versions of web browsers may have limitations or problems, check for any web browser updates, and upgrade to the latest version of your web browser. For Microsoft products, the current status of your software can be verified by the Windows Update web site at: http://windowsupdate.microsoft.com Reset the default BIOS settings: You can try resetting the sound default in the BIOS. Here's how: Tutorial #2: This document applies to Microsoft Windows 98, ME, and XP. If sound is restored when the headphones or one speaker is plugged in, replace the original sound cable with a new sound cable and test for sound. Sound should be restored after replacing the sound cable. If sound does not come back after replacing the cable, the sound card needs to be replaced because the speaker out connector is bad.
Using System Restore
Note: For most PC's entering the BIOS will be the same. If the instructions below do not work for your system, consult your operating manual for instructions on entering the BIOS.
There are many reasons why sound can disappear. The steps inside this document fix a wide variety of sound failures. Perform the steps in order until you can hear sound from the speakers. This document pertains to original sound devices that came installed on HP Pavilion computers. If a sound card was added, consult the sound card vendor's Web site for support information and driver updates.
Step 1: Checking volume and mute settings:
The volume setting for one or more sound devices might be disabled or set too low. Use the following steps to adjust volumes to their correct levels:
In Windows XP, click Start, and then click Control Panel.
In Windows 98 and ME, click Start, click Settings, and then click Control Panel
In Windows XP, open Sounds, Speech, and Audio Devices, and then click Sound and Audio Devices.
In Windows 98 and ME, open Sounds and Multimedia, and then click the Audio tab.
In Windows XP, click the Advanced button under Device Volume.
In Windows 98 and Me, click the Volume button under Sound Playback.
Remove all checkmarks from Mute boxes at the bottom of the Master Volume window and adjust the volume setting slide bars to their highest positions. Close the Master Volume window and test for sound. If there is still no sound, go to the next Step.
Step 2: Verifying the connections:
Use the following steps to verify that the sound cables are properly connected from the speaker to the computer (cable connectors and plug assignments are normally color-coded to aid with connections).
Unplug the sound cable.
Plug headphones or one speaker directly into the speaker out connector on the back of the computer. The speaker out connector may have a symbol of a speaker
or a circle with an arrow pointing out, or it may just say "OUT" next to it. Test for sound using the computer. If sound does not work, go to "Step 3:
If your computer came with
a motherboard disc the sound drivers could be on it click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
