20 Most Recent
AMD Sempron 2800+, 1.6 GHz (G54222) Questions & Answers
Mother board video driver sempron 3100
CPUs do not have drivers. They do not contain LAN, Audio, or Video components. These are part of the motherboard they are installed upon. You need to provide the
motherboard manufacturer, model number, and revision number, along with the specific Operating System you are running. We can then help you find the driver(s) you need.
Amd audio driver sempron
The issue of motherboard drivers is not affected so much by the processor itself as the chipset type/version installed on the motherboard and the operating system you plan to run on it. If you can provide the motherboard manufacturer, its model number and revision, and what operating system you are going to run, we can point you to the correct motherboard drivers.
I need drivers for AMD
Processors don't need drivers. They are supported by your operating system, otherwise you wouldn't be able to install Windows and install a driver for your processor.
What website can i download
Make the FixYa experience better for everyone by voting.Hi,
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
I suggest that you click on the following link and hook up to the largest FREE database on the Internet:
Free Driver DownloadsAll the best
Ben
No sound coming from computer I think I discarded
yes maybe the problem is in the Driver. to check the driver of your sound Go to my computer Icon then right click then choose properties then choose the hardware tab, then click device manager. This will show the hardware installed on your computer and the hardware that needs a driver that shows with a question mark colored yellow. hope this may help you
When i play a audio
Please Reinstall the Audio Driver based on *********** board CD Provided by the Vendor.
Sound not working
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
I want audio driver an
Here is a tutorial and where you can start downloading your graphics drive .....http://support.amd.com/us/gpudownload/Pages/index.aspx......You will also need the Catalyst..... http://sites.amd.com/us/game/downloads/Pages/crossfirex-app-profiles.aspx........... which help with identifying your product...Once you have the product names go back and download the drivers......follow the videos and do the same for the sound device in device manager
Windows Media Player cannot play
This message ussually appears when the audio device drivers are not installed or not installed properly. Clarify me your motherboard or your sound card (in case of a separate one) in order to locate the drivers for you.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I want the VGA driver
The VGA driver can be downloaded by using either the Graphics Card or
Mainboard model number. The Processor doesn't need a driver to operate.
Use
www.nvidia.com and go to driver downloads, then select the Graphics card information.
Now save and run the install.
damnor01
please put here all your pc details then i can help you.I am professional Programmer in driver making.
Give the actual link to download sound,video and
You need to supply the motherboard manufacturer and model not teh chip you are using
If you identify the motherboard name and number, go to the manufacturers website, click on downloads and drivers, you will get the link you seek
There is a sound problem.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
