My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast. With the right external light you could sort of make out what was on the screen by back reflection of what was on the LCD screen.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of
heart. Some offer a replacement service with it. I did mine and it works excellently. An $8 cable and about an hour (plus a lot of pictures-as-you-go for reassembly) is all it takes.
Could you post assembly pictures?
Any chance you could post pictures for the re-assembly?
If you want to take pictures, I can coach you through the process, and then you can post the photo sequence to document the DIY repair. I didn't take photos when I did mine.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
The most likely cause for this is a damaged or defective LCD or flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
