20 Most Recent Sony HDR-XR100 AVC Camcorder Questions & Answers
Recently, I faced the same problem with a Sony XR-155 camcorder while being on vacation. Fortunately, I managed to recover my videos. First, make sure that you as little as possible to the hard drive in the camera menu, so I would not recommend to rebuild the image database or to reformat the drive.
Connect the camera to your PC in the same way that you would usually do. When I tried to access the drive in Windows Explorer, I got a message that the drive was not readable and needs formatting. You do NOT want to do that. I decided to make a full backup of the drive first, so that I could safely fiddle around later on.
The program that I used is Paragon Drive Backup. It gave me a few error messages during the back-up, which I all ignored, and after about 1.5 hours the copy was ready. The next step was to mount the image as to a free drive letter. I figured that I would need some kind of data recovery tool to extract the data, but to my surprise, the mounted disk image was readable in Windows Explorer as if no problem had ever occurred. Luckily, I was able to extract all of my videos from the camera in this way.
Of course I do not know for certain whether this technique also works in your case. For instance, it could be the case that the code E:31:00 is a generic HDD error message and therefore, it might be the case that your camera has a different problem than mine had. However, I think it is worth the shot to try to recover your data in this way (I assume Backup & Recovery 10 Suite does the same trick, a demo version is available on http://www.paragon-software.com/downloads/home/).
This procedure of course does not fix your camera (what I understand from various massages across the internet is that you should send it to Sony to get it repaired), but at least you might be able restore your data. I hope that you will be successful, good luck!
Sony HDR-XR100... | Answered on May 07, 2019
Hi There ...anyhow i have solved this problem
Regards,
Lionel
Sony HDR-XR100... | Answered on Mar 29, 2015
The solution is very simple if your camera has a memory stick slot! For those who has any Sony camera with memory stick slot, try this:
1- Place the memory stick
2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.
3- Go to "Manage Media" again, then to "Format Media", so choose to format the HDD! - Now that you are running the camera from memory stick, you'll not have any problem to format the HD.
At least worked with me! I think it worths the try!
Sony HDR-XR100... | Answered on Jan 31, 2011
Tip
Where to find the manual (pdf) for Sony Handycam HDR-XR100 camcorder
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please click HERE to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the link above. You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturer's contact page , please click on the relevant link below :
Kodak
Sony
Panasonic
Samsung
Fijitsu
Canon USA
Canon Global
Nikon
Phillips
Please rate this tip if you found it useful.
Kind Regards
StephanSA
on Mar 09, 2010 | Sony HDR-XR100 AVC Camcorder
MTS and M2TS format is a Sony hd camcorders and Panasonic camcorders format.if you want to edit your video clips by imovie than you have to convert it to imovie suitable format.you can convert it mov format bfor edit.mov format is commonly use and most preferred for imovie.just download a good converter. http://www.aimersoft.com/convert-mts/convert-mts-m2ts-to-mov-mac.html
Sony HDR Video... | Answered on May 12, 2015
You can download the manual you need here, free of charge:
Sony HDR HC9 manual
Sony HDR Video... | Answered on Jan 18, 2015
If you need help alternating between the modes as well as adjusting any other settings, the user manual for the device should cover everything you need:
Sony HDR HC9 manual
Sony HDR Video... | Answered on Jan 17, 2015
hi
you must have a broken wire in the flat ribbon of the LCD (the one for the blue colour).
you have to replace it
cheers
mich
Sony HDR Video... | Answered on Nov 25, 2014
Sony HDR-XR100 AVC Camcorder Logo
Popular Tags
24 questions posted
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HDR Sony
  • HDR Sony
Most Popular Question
error code e 31 00
  • Video Cameras
