SOURCE: dryer is on and tumbling, but not heating up
Its very hard testing without a test meter.. volts and ohms. The Casing & heater is on the right side facing the back of the dryer. Metal silver in color, the heater is inside of the caseing. You can take the heater out and look for broken coils on the heater to see if it needs replacing. You have a to lift the top up to get at the top screw of the heater casing, take the 2 screws out of the flap where the lint filter goes. Use a putty knife to push the clips in on the front of the dryer and look to the back on the left side to remove the top screw of the casing. check the heater a post results.. theres many more things to check if the heater is good.
First and foremost check your breakers. There will be 2, 30 amp breakers. Even if they don't look tripped reset them anyway. Then try the dryer if that's not the problem then you either have a thermostat problem or heating element and will need to check with an ohm meter.
SOURCE: DRYER WON'T RUN UNLESS YOU HAVE NO HEAT
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
When you get codes it's over!
These are electronics!
Time for the professionals!
For this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
SOURCE: dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
