LG DLG5932W Gas Dryer
Problems with LG DLG5932W Gas Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for LG DLG5932W Gas Dryer RSS Feed
Click here to get instant support from our best Experts!
View More Results for LG DLG5932W Gas Dryer
Questions and Unsolved Support Problems
Unsolved Problems for LG DLG5932W Gas Dryer RSS Feed
Answer
Dryer still turns but only blows cold air
Answer
i have an lg gas dry dlg 7188wm need to change from propane to n-gas how do you get to the oriface
Answer
DLG5932W Gas dryer: small manual reset type of limit switch is tripping operation seems normal
Answer
How do you install the Ignition Control Switch on my LG Dryer
Answer
I have an LG gas dryer (model DLG0332W, not DLG5932W) that is approx 5y old. I have never been... (More)
Answer
Its LG dryer,i got it 3years back and now its got broken inside the drum its working but some... (More)
Answer
I need to get to the orifice to chage it to lp on a lg tromm DLG5966g dryer
Find a Manual
LG DLG5932W Gas Dryer Manuals & Guides
Tips & Tricks
(Post a New Tip)
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE. Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf Also applies to:... written by peonmaster
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for DLG5932W Gas Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Find an Expert
Meet our 2957 Dryer Experts
emissionwiz
Rank: GuruGuru
Rating:  90%, 8135 votes
Solutions:  14852 (927 Votes in the last 30 days)
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
slosmogman
Rank: GuruGuru
Rating:  86%, 305 votes
Solutions:  1196 (545 Votes in the last 30 days)
Experience: ASE Smog Technician Advanced Engine Performance General Handyman
projdoc
#3: projdoc
Rank: GuruGuru
Rating:  94%, 610 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
dmftrucker
Rank: GuruGuru
Washers & Dryers ExpertExpert
Rating:  87%, 412 votes
Solutions:  1582 (409 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
avid101
#5: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1160 votes
Solutions:  2492 (369 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
justaskjoe
Rank: GuruGuru
Rating:  85%, 2014 votes
Solutions:  3902 (353 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
localwonder
Rank: GuruGuru
Rating:  92%, 2797 votes
Solutions:  4947 (328 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
hunter19_46m
Rank: GuruGuru
Rating:  92%, 167 votes
Solutions:  767 (323 Votes in the last 30 days)
Experience: I have worked on many electric dryers in my working career. I am also mechanically inclined.
barkencoa
#9: barkencoa
Rank: GuruGuru
Rating:  89%, 1232 votes
Solutions:  1689 (278 Votes in the last 30 days)
Experience: I am a retired experienced domestic appliance engineer Washers-electric cookers-electric dryers
57 varieties
Rank: GuruGuru
Rating:  88%, 527 votes
Solutions:  1495 (273 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
Find a Warranty
Specifications for LG DLG5932W Gas Dryer
Key Features
Power Source
Gas
Load Type
Front Loader
Dryer Type
Home Dryer
Other Features
Cycles
9 Cycles
Cool Down Feature
With Cool Down Feature
Quiet Mode
With Quiet Mode
Energy Efficient
With Energy Efficient
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
28.38 in.
Overall Height
42.75 in.
Overall Width (Display)
27 in.
Warranty
Warranty
1 Year
LG Contact Information
Main support number1-800-243-0000
Email supportcustomerservice@lge.com
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
