The problem lies partially with the tank valve and the way it was turned ON.
To solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's
Hose/Regulator Assembly. It runs about $30.00 at any home center or
hardware store that sells grills & accessories. If you replace it,
turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
No, not necessarily. It happens with brand new grills. The OPD (Overfill Protection Device) in the tank valve is what causes it. When the tank valve is opened to quickly (like you could with older tanks), it shoots to much gas to the grill regulator and locks it up. Opening the tank valve Very, Very, Slowly doesn't allow that to happen.
I'm glad I could help you and thanks for the 4-Thumbs Up Rating. I really do appreciate it.
Worked exactly as posted. Thank you. This probably means the regulator valve is getting weak and will need replacing.
