1994 Toyota 4Runner Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is used as coolant in the radiator of 1994 4runner? water or something else?
Anonymous
Level 2:
Sergeant:
  • Expert 203 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
203
Questions
Helped
61687
Points
616
No just water some say distilled water.but a 50/50 mix of antifreeze/water
Randy Ohler
Level 3:
  • Toyota Master 14,585 Answers
Randy Ohler
Toyota Master
Level 3:
Answers
14585
Questions
8
Helped
3947468
Points
39683
Green colored antifreeze. You can use just water, but it is not good for the engine parts. Antifreeze will not freeze and it has a lubricant in it for the water pump and rust inhibitors. For -20 degrees farenhight mix it 50% water 50% antifreeze.
Jonah Oneal
Level 3:
  • Toyota Master 14,092 Answers
Jonah Oneal
Toyota Master
Level 3:
Answers
14092
Questions
0
Helped
7242207
Points
44533
YOU SUPPOSE TO USE 50/50 GREEN ANTIFREEZE AND WATER TO COOLANT SYSTEM. IF YOU USE STRAIGHT WATER IT WILL BOIL EVAPORATE AWAY WHILE ANTIFREEZE WILL RAISE BOILING POINT.
2answers
How do i drain radiator
Most radiators have a 1/4" drain cock at the bottom of the reservoir.
If not??? (haven\'t seen one yet) then remove the bottom hose.
Make, year & model of the vehicle will help. And if the radiator is original.
2answers
Coolant
Its not too difficult. The is a canister that contains the coolant. Just undo the cap and top up. Be sure you use coolant to the same specs that is already there. If not, you'll have to drain out the old one and top up with completelty new coolant
Where is the waterpump to add coolant and water in santafe 2005?
The water pump is enclosed on the front of the engine. The bottom radiator hose connects to the water pump inlet.
You do not add coolant to the water pump. You add a 50-50 mix of antifreeze and water into the radiator cap opening. Or you can buy the coolant already mixed with water and just pour it into the radiator.
The coolant system uses the water pump to circulate the coolant through the engine and then into the radiator via the upper radiator hose for cooling it off, and it then goes back into the engine through the bottom radiator hose. When the engine is warmed up, the coolant constantly circulates through the engine to radiator and back into the engine.
2001 chrysler voyager coolant leak passenger side
what i did was use some printer ink "yellow" and put it in my radiator. its water soluble and then ran it for a day and i found the leak at the water pump bearing im not shure where yours might be but this will help you locate it. hope this helps. take care.
6helpful
2answers
My coolant is leaking and its a big possibility it might be the water pupm or radiator but i think its just a hole in the container that holds the coolant, is ok if i put water in there constant to keep...
Stop leak is a temporary solution and never a long term fix. You need to locate the source of the leak and replace the faulty part. I also doubt that the coolant overflow reservoir is leaking unless something has been done to the vehicle to damage it.
Using water rather than the correct spec coolant mix as a top up is NOT recommended (even for a short period) because, among other things, the coolant mix provides lubrication for the water pump. Constantly adding water rather than the correct coolant mix dilutes the coolant mix and it becomes ineffective.
Your engine needs an efficient cooling system to survive so have the leak investigated and fixed saspo.
If you allow the engine to overheat you will cause very expensive engine damage and end up with a car you will not be able to drive. It is always cheaper to fix the problem.
2helpful
2answers
How do I drain coolant from a 2001 ford mustang GT?
unscrew the freezeplug located on the bottom corner of the radiator
2answers
Where can I get solid/detailed instructions for changing out the water pump on my 2001 Yukon SLE 4.8? Something that would include torque specs. and any must does and don'ts would be nice.
Escalade, Suburban, Tahoe, Yukon, Denali, DenaliXL, YukonXL 1999-2005 Water Pump - Removal & Installation 4.8L, 5.3L & 6.0L Engines
  1. Remove or disconnect the following:
    Air outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
    Fig. Exploded view of the water pump assembly-4.8L, 5.3L and 6.0L engines
To install:
NOTE DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
  1. Install or connect the following:
    Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 11 ft. lbs. (15 Nm); tighten the bolts final pass to 22 ft. lbs. (30 Nm). Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 89 inch lbs. (10 Nm); tighten the bolts final pass to 18 ft. lbs. (25 Nm). Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet duct Coolant
    Air inlet and outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
To install:
    Water pump. Install the water pump bolts. Tighten the bolts to 11 ft. lbs. (15 Nm) for the first pass; then tighten to 22 ft. lbs. (30 Nm) for the final pass. Water pump drive belt pulley and bolts (if applicable). Tighten the bolts to 89 inch lbs. (10 Nm) for the first pass; then tighten to 18 ft. lbs. (25 Nm) for the final pass. Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet and outlet duct Coolant
Hope this help to solve it (remember comment and rated this).
2helpful
Where do i refill coolant? message reading low engine coolant.
please rate, thx Coolant Recovery System NOTE: When the water thermostat (8575) is closed, there is no flow through the radiator coolant recovery reservoir (8A080).
Trapped air in the cooling system must be removed. A pressurized radiator coolant recovery reservoir system is used which continuously separates the air from the cooling system.
  • When the water thermostat is open, coolant flows through the small hose from the top of the radiator outlet tank to the radiator coolant recovery reservoir.
  • The radiator coolant recovery reservoir separates any trapped air from the coolant and replenishes the system through its radiator coolant recovery hose to the water thermostat housing.
  • The radiator coolant recovery reservoir serves as the location for:
    • service fill
    • coolant expansion during warm-up
    • system pressurization from the pressure relief cap and
    • air separation during operation
  • The radiator coolant recovery reservoir is designed to have approximately 0.5-1 liter (0.53-1.06 quarts) of air when cold to allow for coolant expansion.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
