I actually have an MH1150XMT-0, but that model dosen't seem to be available on the site... but anyway...
My control panel is in the process of dieing.. some buttons work, some don't and I can no longer turn on my microwave (I could when it started) but the start button and add minute buttons are now amongst the dead...
Most of the advice I've found here (and elsewhere) is about totally dead controls, not partially...
I'm pretty decent with taking things apart and such, but I can't find a catch or screw on the (apparently) modular panel and I'm afraid to just yank it off and look... any help?
In order, I would suspect:
- it needs a reset
- door switch or door switch mount trouble
- your keypad is failing
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it so I can give you some advice on the other two probable causes.
I have a similar problem, the control panel works intermittently, and when it doesn't it displays an F2 error code. Elsewhere on the net it said F2 indicated a shortcircuit. Can I simply purchase a new control panel and install? How easy is this?
