Thats the classic sign that your flyback need sreplacing, very easy repair . You need flyback number 259296 you can get a replacement with free step by step instructions on how to replace it yourself at the following link. http://servicemanuals.vstore.ca/
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
maybe you did the child lock which doesent allow you to turn the tv on unless u clck some buttons look in ur booklet and search for how to unblock the child lock or the 2nd try the turn on button and the ok button at the same time if it doesent work forgive me this happend to me as well
Check the horizontal output and regulator transistors. If you ould like the service manual let me know I can post a link where you can purchase it and have it emailedto you along with free help to elp you diagnose and repair your set.
