Televison & Video Logo
I turn the tv on the green light comes on three times but no pic
When I turn the tv on the green light comes three times but no picture or sound. Then after the third time the green light goes out all together.
Posted by fannie_mcwho on
Anonymous
Maybe you did the child lock which doesent allow you to turn the tv on unless u clck some buttons look in ur booklet and search for how to unblock the child lock or the 2nd try the turn on button and the ok button at the same time if it doesent work forgive me this happend to me as well
Posted on Mar 17, 2009
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
My RCA model # HD52W59, power on and shuts down without coming on. Green come on then shuts down. No picture or sound.
The set is in shutdown because of a problem inside, this model has the three strikes and your out, it will try three times to come on and then latch down. It likely needs a shop repair of some kind.
1helpful
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
1helpful
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
1helpful
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
3answers
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
3answers
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Top Televison & Video Experts
Marvin
Marvin
