I have video on my camcorder and I am trying to save them to dvd+r disk. The files saved as .MOD, MOI, PGI files I am losted with those extentions. I don't want to mess things up. Can you please help
If you got discs with the camera look for a program on there called Cyberlink Power director it will convert the files for you heres a link that will give you full instructions as well as a link to Other programs that will do the job
MOI is a computer file format used primarily to represent information. MOI files are associated with MOD or TOD files whose content they represent. The Pixela ImageMixer Video Editing Software should allow you to save your videos to your hard drive. But you may need to install the latest version of Quicktime Player (free) to view the the .mov files as an alternative to the ImageMixer program's viewer.
Source(s):
http://www.apple.com/quicktime/download/
It all depends on what file type your camcorder save video's in and what file types are compatible with your DVD player.
Many camcorders save files on a card as MPEG4, you have to check what yours does.
Its ok to write to a DVD but you have to make sure your DVD player can play MPEG4. If not then convert your files or save your files in a format your DVD player can recognise ie MPEG1 or AVI.
Finally, once you've copied videos in a format your dvd plays, make sure you "Finalize" the disk. This means that you can't copy any more data, but it makes the disk readable on other players.
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Your computer should be reading your connected camcorder as an additional drive or hard drive (not folder) when connected. Here are some tips to make this easier for you (Make sure your camcorder is on movies not pictures when you do this):
Steps:
1. Connect you usb to you computer and camcorder
2. Camcorder ask do you want to playback, backup, create dvd, direct print.... Choose playback
3. Option pops up on your computer.. Select "Take No Action"
4. Go into My Computer and open the E: or Everio_HDD
5. >>For movies- Select SD-Video - Folder PRG002 or PRG001 are where your movie files is located
Drag and drop .MOD files to your desktop **.MOI files are indexes of the .MOD files and will not convert **
>>For Pictures- Select DCIM - Folder 101JVCSO or 100JVCSO - Drag and Drop to desktop - NO FILE CONVERSION NECESSARY
6. Change the file extension to .MPG
** If you find yourself haveing issues changing the file extension, open my computer... select tools... go to folder options.... uncheck "Hide extension for known file types", check it back when your finished if you have kids.. I do for my computer.***
**You are simply creating copies of your files when you drag and drop you movies and pics***
No changing of file extensions is necessary if just saving to computer and you have the software.... but file extension change will allow you to view back movies with Windows Media Player.
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Drgadgt
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
as stupid and simple as it sounds:
rename the file extension to %filename%.MPG and it will play with your normal video player (I use VLC player).
found this solution on some other site, was sceptical, but it really works.
Actually, converting the .mod file to .avi or .mpg is not sufficient. The corresponding .moi file contains date/time stamp info. as well as some resolution/aspect ratio info. There is a free utility at the following link: http://zyvid.com/smf/index.php?acti...ic=280.0;id=153 that does a really good job at converting the .mod/.mov files into .mpg files properly.
