20 Most Recent
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Questions & Answers
My camers keeps on asking me to
I found the fix. It's so easy.
Take out the battery
When it says hit the reset button, hit the reset button.
Turn the camera to off
Wait 2 minutes
Put the battery back in.
Turn on the camera. It won't say reset anymore.
10/18/2012 11:44:10 PM •
Panasonic...
Answered
on Oct 18, 2012
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc. It has always gone back in eventually. I also tried re-charging the battery and replacing. Could this be an old battery problem? Mine is 4.5 years old.
9/15/2012 2:13:43 PM •
Panasonic...
Answered
on Sep 15, 2012
I ve the palmcorder which when powered it only
Sometimes the batteries for these camcorders just go bad. There's nothing you can do to fix the battery itself, but you can find them really cheap online. If you don't think the battery is bad, and you just don't know how to charge the battery, you can find the manual on Panasonic's site. You can click support, and there will be a place to enter the model number. It will be on the camera, probably on the bottom. If you enter a model number that doesn't fetch results, try a different number (or combination of letters and numbers) until it does find results for your camera. Most of these small cameras have a small door, or attached cap that you have to pop up and open with your fingernail (they are small, so look carefully, most likely around the bottom or back of the camera). Plug the charger in and wait to see if the battery charges. If it does, the Palmcorder will stop turning off a few seconds after you turn it on.
4/15/2011 9:21:38 AM •
Panasonic...
Answered
on Apr 15, 2011
I have pvgs9 recorded item
Hello - You need a few things to do what you want to do.
1) you need a firewire cable (not included with the camera) to connect camera to PC.
2) You need a firewire controller in your computer to connect to.
3) You need capure/editing software that will do the work once you're physically connected.
I don't usually grub video from YouTube but this under three video does a great job explaining the basics better than I could in a paragraph or so.
Click Here
Have fun if you decide to go forward!
Regards,
Mikeywaf
3/8/2011 5:35:53 AM •
Panasonic...
Answered
on Mar 08, 2011
How do it ransfer video from my pv-gs9 to my
I don't understand the "firewire to USB cable" reference. You can't just connect these two incompatible interfaces together with a cable. There is some kind of conversion device available to allow a Firewire connection to be made to a USB port, but the chatter on the forums says that it doesn't work with video cameras.
Some mini-DV cameras have a USB port, but only use it for stills and can only download video by Firewire. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
You don't say if you have the manual available for reference. If not, you can download a copy from
THIS LINK
11/17/2010 3:28:09 PM •
Panasonic...
Answered
on Nov 17, 2010
The tape loading mechanism on my Panasonic PV-GS9
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
10/18/2010 5:25:07 PM •
Panasonic...
Answered
on Oct 18, 2010
Reset button display, pops out
If you are talking about the "Push the Reset Button" error message, then you have connection issues on your main PCB. This repair would need to be done by an experienced technician. We have been successful solving this problem by repairing PCB connections and applying a special antioxidant grease to the connectors to prevent future occurance.
www.austintelstarservices.com
9/3/2010 7:00:39 AM •
Panasonic...
Answered
on Sep 03, 2010
I have a MacBook pro and no software for my
The cord that comes with the camera is a USB cord. USB on this camera is used only for downloading still images. You need to get a Firewire cable and use that. Once you hook up the camera through Firewire, open up iMovie and turn the camera to VCR mode or turn it on. It should pop up with a window asking you to import.
2/22/2010 8:55:58 PM •
Panasonic...
Answered
on Feb 22, 2010
Getting message to push the reset switch but no
Please remove battery/ power source from camcorder for 15 seconds, reattach battery/ power source, turn it ON, when asks push reset button, push it, turn off camcorder, remove battery/ power source again for one minute, reattach battery/ power source and turn it ON. push reset message wont come up.
2/3/2010 12:08:15 AM •
Panasonic...
Answered
on Feb 03, 2010
New laptop with Windows 7 and an old camcorder Panasonic PV-GS9
According to Microsoft there is currently no compatibility. (see link)
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Panasonic%20PV-GS9%20MiniDV%2020X%2F800X%20Camcorder&v=Panasonic&uid=PV-GS9&pf=1&pi=1&c=Cameras%20%26%20Photo&sc=Camcorders&os=32-bit&vd=all
12/30/2009 12:18:25 AM •
Panasonic...
Answered
on Dec 30, 2009
