SOURCE: how to change IRQ settings
In windows we dont have any in built utility but you can easily download some utility to change the IRQ number. Good luck
SOURCE: IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
SOURCE: Hi i have IBM R52 but i dont have any drivers,how
you can find the drivers here - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58931
for windows 7 the vista drivers should work
SOURCE: ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
SOURCE: I cannot install windows xp in ibm x3400,the
I believe your HDD must be a SCSI disk whose drivers might have come along with the HDD.While installing XP it gives an option to install third party drivers for your HDD, Hopefully after that it would start detecting
